Thread: Water Clarity Question
    My pool water became cloudy ( blurry ) . Looks fine from above the pool but when swimming its blurry. Is it algae ?
    This is a 20k SWG pool . My current readouts are :
    FC : 5
    Salt : 3200
    CYA : 40
    TA : 110
    pH : 7.7
    Pho: 300
    Pool is been getting warm ~88 - 90 degrees. Its covered with a solar cover. Pump runs for 6 hours / day.
    Should I shock the pool ? Let pump run longer ? What else could be causing water to not be clear ?
    20k gallon +7ft spa, Cartridge, IG , Plaster, Salt system Hayward, Hayward EcoStart Pump, Hayward filter & heater.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Water Clarity Question
    drudnev:
    Welcome to TFP
    Your FC of 5 ppm is good for your CYA of 40, but do you know what your CC is? You could also run an OCLT (see link in my sig) to see if there is anything organic trying to set up shop in the water that has not yet made it presence known visually aside from the water getting a bit cloudy .
    Barring a pool party or suddenly high bather load within the past day, I don't think pump run time is the culprit here.
