Results 1 to 9 of 9
Thread: Very nervous about setting up the new pool!!
    May 2013
    Mid-Western Ontario, Canada
    15
    Hello All,
    I am newly registered to this forum and have very little to no previous pool experience. I have had a pool up for the past 2 summer seasons prior to this year but failed miserably to the point we had black water & a dead bird floating in the pool at the end of last season. I am hoping to figure our water chemistry out and what I need to do before I even set up this pool and way before running into the same problems!
    I unfortunately am not able to purchase one of the more expensive testing kits at this time. I am hoping to in the future. As for right now I do have the HTH 3 way test kit with results taken from my tap water. With that said, I would like to at least purchase the HTH 6 way test kit from Walmart but my local store does not carry it. I am travelling to the city next weekend to try an track it down. My current store does carry these two options: HTH 3 way test kit (drops, I have this), HTH 3 way test (strips, I have this), HTH 6 way test (strips, do not have this). Would it be worth my while to get the 6 way test strips if I do not find the 6 way test kit (drops)? Or are the strips really a waste of time?
    I really struggled with figuring out what in the world I was suppose to be adding/balancing my pool with last year. I tried to talk with HTH directly through chat and they had me purchase and use 5 large containers of Alkalinity down and a bunch of others such as Sock it, Algaecide, Granular Chlorine, Stabilizer & I can't even remember the rest. At the time I was only testing with the 3 way test strips and the levels were literally never where they needed to be. I was getting more pregnant and uncomfortable as the summer went on and eventually gave up which led to the black water & dead bird I spent loads of money and never had the dream pool for my family I so desire.
    I am hoping to get a little insight, even if I can be pointed in the right direction for where I should be reading about initial set-up and testing. Does anyone have a good idea where to start?
    Thank you soooo much for any help in advance. My family will so appreciate a beautiful safe pool for cooling off in during the summer.
    TEST RESULTS: (adding a photo of my 3 way test kit, drops)
    FC - Free Chlorine - Way darker than the highest colour 3.0 on test tube.. is this the FC, CC or TC showing on this test?
    CC or TC - Combined Chlorine or Total Chlorine - answer above maybe?
    pH - maybe around an 8.0? test goes up to 8.2 and I am having a hard time decifering if it is lower or higher than that (attached picture for your diagnosis) I find my test water more of the pink/orange, less darker red & therefore assuming it is lower but i really don't know what to make of it.
    TA - Total Alkalinity - Unknown
    CH - Calcium Hardness - Unkown
    CYA - Cyanuric Acid (stabilizer/conditioner) - Unknown
    3,754 gallons of water at 80% capacity, AG Inflatable Intex Pool, Krystal Clear Cartridge Filter Pump 120 volt with 3,785 L/ph flow rate (1,000 gph), Intex Filter Cartridge Type A, Brand new not yet set up pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Very nervous about setting up the new pool!!
    Check out Pool School for the info you need. Your tester colors look reasonable. Your pH is probably 7.6 or so, and your chlorine is around 3ppm. Without knowing CYA, I can't tell you if that's enough chlorine or not.
    The most important thing is to ensure you have enough chlorine in the pool 24/7. Everything else can be adjust at a more leisurely pace. Having a reasonable CYA level will help you maintain your chlorine during the heat of the day.
    Jun 2012
    Howell, NJ
    977
    Since you say you can't get the good test kit, the Wal-mart one will suffice for now. Don't even bother with the strips, as they are wildly inaccurate. When you do get the HTH kit, you will only be missing the FAS-DPD chlorine test, which can be bought separately. To complete the kit, this is what you will eventually need: http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html I should mention, that if the pool is cloudy (is it?) you will need to go through the shock process, which can only be done with the FAS-DPD test.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    May 2013
    15
    Thanks so much for the replies JohnT & JohnN!! Thank you for the accurate reads JohnT I have no idea what I am trying to see with the colour testing. I will also check out Pool School Thank you JohnN for the link to the additional FAS-DPD test. I will try my best to track down the 6 way hth next weekend. I actually do not have the pool set-up/filled yet. I am wondering if there is somewhere I can be pointed in the right direction in order to figure out how to set it up properly? Something that can tell me what chemicals I need to add and what increments etc upon setting up.
    Thank you for your help guys!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Hate to break it to you, but you won't be able to order stuff from tftestkits. Taylor has granted a monopoly in Canuckistan to someone else.
    If you have reason to cross the border, however...
    May 2013
    15
    Hi Richard Shoot! They don't even sell the HTH 6 way test kit in Canada Arg, not sure what I can get/where I can find something. Called my local pool store & left a message. They will get back to me after the long weekend. Until then any suggestions on where to possibly purchase 6 way test kit in Canada?
    Jun 2012
    Howell, NJ
    977
    You could take a road trip to California and order from PoolSupplyWorld... But seriously, do you have any friends/relatives that live in the US? Maybe you could have them order it and then forward it to you.
    John
    Jul 2012
    Waterloo, Ontario, Canada
    10
    You can order the Taylor kit from Paul Giroux at Piscines Apollo Pools, (piscines-apollo.com). They are located in Quebec, are very responsive and ship very quickly. It's more expensive than south of the border, but should last the year, and after that you just have to order any reagents you're short of. When you factor in the savings from treating your pool from accurate test results, you'll still end up way ahead.
    21,000 gallons (81,000 litres) inground vinyl, 16 x 32, Hayward S-244T sand filter, Hayward 1 hp superpump - 2 speed, Hayward 250,000 BTU Nat Gas Heater
    May 2013
    15
    awesome thanks for the advice
