Thread: Just ordered FAS-DPD test kit
    Since the kit I just bought only goes up to 5ppm for FC I ordered the FAS-DPD only test kit. I read that it comes with 10g of powder and when I test I need 1 heaping teaspoon full. When I did the teaspoon to grams conversion online it says 1 tsp equals 4.745 grams. Doesn't that mean that i'll only be able to get about 2 teaspoons per 10grams? I'm really bad with conversions. This doesn't sound right to me because if that's the case how many extra powders should I order since I need to shock my pool up to 20ppm and keep it there till clear and need to start testing it every hour then every 4hrs then every 8hrs.
    Am I just confusing myself for nothing? That is easy for me to do
    18'x48" easy set pool w/Intex SWG
    There is a teeny, tiny measuring spoon included in the teskit, it is NOT a teaspoon. You will get MANY tests out of 10 g of DPD powder. You need a rounded measuring spoon full which is probably around 1/32 of a teaspoon (just a guesstimate. I did not measure it!)
    just to be safe I ordered extra powder. I have enough to check all the neighbors pools, too!!
    Oh well, better to have more than not enough.
    MikeInTN's Avatar
    Middle Tennessee
    Put it somewhere cool and dry. It'll keep.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
