Results 1 to 15 of 15
Thread: Need a little help opening pool / balancing water
    May 2012
    Allentown, PA
    219
    Just opened today. I can see down about 2 feet and the water has a nice greenish tint. Reminds me of when my pool contractor told me that with this new solid winter cover I'll just pop it off and the water will look perfect. What do you expect he worked for the pool store.
    FC 0
    PH 7.0
    TA 80
    CYA 0
    CH 110
    Not sure what order I should go about attacking this, and what I should add. The good news I have lots of bleach
    Thanks for the help.
    21,500 Gallon Vinyl liner pool Eastern Pennsylvania
    Hayward 2 HP pump 2" Pvc pipes Full Sun Pool
    Hayward sand filter, Compupool CPSC 48 SWG
    12mil solar cover and reel
    Feb 2008
    Denton, TX
    5,061
    Re: Need a little help opening pool / balancing water
    Did you get your test results with the pump running? If not, go ahead and fill it (if it needs it) and then start the pump up. Circulate the water for at least 30 minutes and then test. Adjust pH to between 7.2 and 7.4 first, add enough CYA to get you to 30, and then shock your pool. You are finished shocking when your FC holds to withing 1 ppm or less of FC overnight, your CC is no more than 0.5 ppm, and your water is clear.
    May 2012
    Allentown, PA
    219
    Thanks for the quick response. The pump has been running for 3 hours, so I think my water is mixed. I'll let you know how I'm making out.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by doublewide6
    What he said. And if it's not too late, don't just dump the CYA in the skimmer. If you need to backwash during the shock oprocess you might lose it all, and we're about saving money here.
    May 2012
    Allentown, PA
    219
    I brought up the ph and added CYA in socks in the skimmer. I only had 4lbs. of cya that should bring me to 20ppm. Can anyone tell me how much one triclor puck raises cya in a 20,000 pool? I'm thinking about adding a floater with a few trichlor pucks to raise cya to 30ppm. I can't figure out how to do it using the pool calc. Thanks again
    Jun 2012
    Howell, NJ
    977
    There is a section at the very bottom called Effects of adding chemicals.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Richard320's Avatar
    Jan 2010
    19,051
    What he said ^
    Each 8 oz trichlor puck will raise CYA 1.7 in your pool. Pay attention to what it does to pH, too!
    May 2012
    Allentown, PA
    219
    Quote Originally Posted by Richard320
    What he said ^
    That is what I really needed to know the weight of one puck. Thanks
    May 2012
    Allentown, PA
    219
    So this morning I worked on getting the pool clear. I added lots of bleach, but it was not registering for my FC tests (only 15 min. after adding bleach). So I kept adding bleach and testing. Finally, I made progress and registered my FC at 8ppm. I brought it up to 20ppm to make sure it stays there. I guess all the scum in the pool is eating away my bleach quickly. Just wondering if the cya chart in pool school is made for a pool that has been closed and now just opened. It seems to me the chart is underestimating how much bleach needs to be used, so I usually shoot for a level or 2 higher as my target when I open my pool. Is this common?
    Jun 2011
    Long Beach, CA
    2,790
    What was your CYA level when you closed? With it being at zero when you opened, ammonia might be in your water. Chlorine will be absorbed almost instantly to get rid of the ammonia. There are a couple of other threads with the same problem and you can search those threads to get more insight. Since you are starting to hold the FC, you should have eliminated most of the ammonia already.
    May 2012
    Allentown, PA
    219
    When I closed CYA was about 30ppm. The test kit only reads down to about 30ppm, so I don't know for sure if it is at zero. It might be around 10, so I'm targeting 30. I will read up on ammonia.
    May 2012
    Allentown, PA
    219
    So it has been 5 and a half days since opening the pool. The pool is looking better everyday. I added 4 lbs. of CYA enough to raise my CYA to 20 and also 5 triclor pucks to the pool (I also added some washing soda to keep my ph around 7.3) All the cya dissolved from the socks. I just tested CYA today and it is still registering less than 30ppm. I did notice the water sample for the cya test was at least slightly cloudy for this test but definitely not registering 30ppm. I have come to the conclusion that I may have had ammonia in the water when the pool was opened. I added the cya in socks and squeezed the socks each day when I checked the skimmers. Should the cya be registering by now? Should I add more cya, and if so, how much?
    Jun 2012
    Howell, NJ
    977
    It can take up to a week for CYA to show up on the test. I believe that means a week after it is fully dissolved, but I am not sure.
    John
    30,431
    One week from the day of application.
    May 2012
    Allentown, PA
    219
    Thanks for the quick responses. I will wait 10 days from initial application, then retest. At least I know my CYA should be close to 30 and not 0.
