Results 1 to 10 of 10
Thread: Best method for adding Calcium Hardness increaser
    Nov 2010
    South Central Kentucky
    283
    I have the powdered form of Calcium Hardness increaser. Last test showed CH at 170. I'd like to bump it to 200, which according to the calculator will take 64 oz. by weight.
    What is the best way to add the calcium? Broadcast it across the surface and brush, sock method like CYA?
    FYI, other numbers are:
    FC - 10 (needed to add salt this morning so I bumped it on the way out with bleach, little too high on my guess...)
    CC - 0
    TA - 80
    CYA - 55 (calculated based on addition) waiting to test in a couple of days to bump a little higher ~70.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Best method for adding Calcium Hardness increaser
    There really is no reason (typically) to raise the calcium level in your vinyl lined pool.
    Nov 2010
    283
    The only reason I'm concerned are the specs for the SWG and the heater which want the CH level from 200 - 400. If it's not going to hurt anything I'll leave it, just didn't want to cause any potential issues with that equipment.
    Nov 2010
    283
    Other than that, do the rest of the numbers, other than the FC needing to drop, look good? I'm keeping the FC elevated for a few days in hopes that some stains on the bottom will disappear.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It won't hurt anything. Both the swg and the heater actually benefit from low CH. The only issue may you may have is if you are still under warranty for those components...are you?
    The rest of you numbers are looking good.
    Nov 2010
    283
    No warranty left. I'll leave it alone.
    Just so I know though, how do you add the Calcium, best method?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by joshs2000ss
    The secret is hidden within Pool School.
    But I'll give you a hint. pool-school/recommended_pool_chemicals
    Nov 2010
    283
    Thanks. Sorry for not finding that myself. I was searching forums instead of just looking to the main source...
    May 2012
    Brevard Co., FL
    29
    The best method for adding calcium hardness is to bring a tanker over to my house and fill it up with water from my pool. I am draining it again because of high CH. I will be glad when it cures.
    12000 GAL Total Pool & Spa-1000 GAL Spa/IG/Exposed aggregate/Cartridge CC200/Pentair VS-3050 (174 GPM max.)/SWG-Pentair Intellichlor IC-40/Pentair EasyTouch4/ "The Pool Cleaner"/Screened Enclosure/ Taylor K-2006C Test Kit.
    Richard320's Avatar
    Jan 2010
    18,995
    Quote Originally Posted by FLHOKIE
    I'm at 875. Can you beat that?
