Results 1 to 8 of 8
Thread: Normal chlorine loss?
    Mar 2013
    South Windsor ,CT
    22
    New BBBer here
    I was just wondering what the normal loss in a day might b 4 me .
    I have 21000 gal IG vinyl liner Cya is 40
    All numbers in range.ch was little low but that has no affect on me. Right? Another question I have is how can I stop birds from
    Dropping turds in my pool. No sooner than my robot finished even before I got
    Him outta the pool was I starring at a dirty bottom again. Yes it was clean
    when he finished
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jandy aquapureIE SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Normal chlorine loss?
    Welcome to tfp, Pdouble
    It is hard to say what you should see, it depends on sun exposure, typical swimmer load, other organics, the bird droppings, your cya level, your FC level, etc. With that said, when the typical pool is running the methods taught on this board a typical loss is ~ 2ppm/day.
    Mar 2013
    South Windsor ,CT
    22
    Forgot to. Add all sun all day. No use yet do to water not over 70 degrees
    But waiting 4 the day
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How does your water look?
    Mar 2013
    South Windsor ,CT
    22
    Crystal clean minus the pollen. I'm useing 40-70 oz of 12.5 a day.
    This is my first pool just moved in 4 weeks ago and opened
    The pool 2weeks ago. Clear when open did shock
    Process about a week long till passed all three
    Even blew away the Leslie's pool store owner
    When I brought my water in 4 a test ( I got a TF100)
    She said " you must have been doin this for along time "
    When I told her it was my first pool her jaw dropped
    Told her I'm a BBBer and still tried to sell me stuff
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jun 2012
    Louisville, KY
    266
    Nice job! You can monitor your FC loss and bump your CYA up to 50 if you want because of all day sun. Just make sure to follow the CYA/FC chart and never go below minimum.
    On the birds you can google about a myriad of ways to attempt to keep them away. I like having them around personally. One used by my boating buddy's is to place rubber snakes around the pool or boat area. Another is a owl statue or two that hoots every now and then. You can rent tigers for a week as well if the birds are larger but you have to feed them.
    Depending on where you're located a good solar cover works wonders for keeping the water up to temp.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Mar 2013
    South Windsor ,CT
    22
    I would get a tiger if I could train it to not eat the kids
    21000 vinyl IG
    TF100
    Jacuzzi sand filter
    Aquabot AWD
    Jun 2012
    Louisville, KY
    266
    Ever thought about Falconry?
    Sorry for the off-topic. Couldn't help myself.
