Thread: Took the some turns out of the pump intake - Opinions
    Jun 2012
    Oakton,Va
    39
    Guys - the intake system for the pool had a bunch of turns. Taking you advice I set out to eliminate as many as possible. Can you take a look this is configuration and provide feedback before I fit everything and glue. (Note this only roughed in)
    Regarding the vertical SPA jandy I know it looks like I could place it horizontal - but I can't. there is not enough space even with 2 jandy valves touching.
    Before
    [attachment=1ovn0qgt]mini-pool config.jpg[/attachmentovn0qgt]
    and purposed After shots attached(sorry for the crappy phone pic)
    [attachment=0ovn0qgt]IMG-20130517-00165-small.jpg[/attachmentovn0qgt]
    35000 gallon inground, 2hp Whisperflo, Pentair FNS Plus, Polaris 380
    30,426
    Re: Took the some turns out of the pump intake - Opinions
    Well, if it's not put together yet, I see no reason not to move the pump about a foot to the right and eliminate the 2 90's on the suction side of the pump.
    There probably is a reason why not but I don't see it from the pics.
    38,359
    I think Dave only saw the before picture.
    Your after looks ok, are you going to need 2 more 90s to drop to the pump? Going to be a little annoying to turn that one valve, Youmay want to flip it to the other side.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Jun 2012
    Oakton,Va
    39
    I am going to try and cut it down so it would be a straight shot into the pump.
    Turning the valve around - Yes thank you good pick up b/c the pipe would be going across the top of the handle.
    I'll cut everything down today and do a formal dry fit - I actually plan on dry fitting the whole thing (return side) before the glue comes out....
