Thread: Considering AquaLogic Automation System
    So.. I'm considering an AquaLogic automation system. I haven't yet switched to SWG but have definitely decided that I'm going to. When considering installation, I asked my local pool store if they had installed this system before. They are actually a good non typical pool store. Their tests are usually very close to what I obtain using my T100 kit. Most of the staff is very knowledgeable and don't employ sales gimmicks. They then asked why I wanted automation over an Aquarite system. I stated I am currently running my pump 24/7 and wasting alot of energy. They suggested that I should be running 24/7 in the summer. I live in East TN, we have hot but not scorching summers. Am I unrealistic to think I should be able to cut my pump down to 12 hours or even 8 hours of run time a day and still achieve proper sanitation? Is there a better system available for automation, I currently have all Hayward products so thought I should stay that way.
    Adam
    -30k gal, vinyl, 1 HP Hayward pump, sand filter, Dolphin Premier cleaning robot
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Considering AquaLogic Automation System
    I run my pump 4 hours per day (@ 95%) so I think you could go down to at least 6 hours, assuming you go with a T-15 Cell. But it depends a little on what is falling into the pool and how much chlorine demand you have.
    Mark
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Do you have a variable or 2 speed pump?? Here in FL, hotter here than in TN most of the time, pools run 8-10 hrs during the summer. No problems with pools here. Unless it's a commercial pool. I don't see why a residential pool owner would run a pool 24/7 unless of course you run a variable speed pump on its lowest speed all the time.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
