Results 1 to 14 of 14
Thread: My new-to-me pool (PICS)
    we are closing on the hose June 24th if all goes well. I went out to the house yesterday to do some measuring, check out the pool equipment, etc....
    Here is what I found:
    When I was at the house three weeks ago there were a few patches of what appeared to be floating algae, but the water was clear. I could see the drains pretty clear in the deep end. Now it's starting to get pretty black & nasty.
    The pool is 20'x30' (not including the steps)
    The attached spa is 8'x4'
    The pool and spa were renovated a couple of years ago by Blue Haven. What I read online left me feeling not so good about them, but supposedly everything works fine. The plumbing looks to be well done & all of the valves are labeled. Here is what I know of the equipment All Blue Haven branded Hayward stuff from what I could tell:
    Hayward cartridge filter
    2 HP SmartMax pump (Hayward TriStar?)
    Pentair Model 230 inline chlorine feeder
    Lots of valves... One labeled "cleaner".
    A timer box on the wall
    AquaComfort heat pump (AC-150 I think)
    Silencer Jr. 2HP spa blower
    The seller is supposed to open the pool and get it cleaned up prior to closing, so I shouldn't have too much of swamp this summer, but in the pump room there were several buckets of triChlor, so I may have to do some draining/ filling to get the CYA in check.
    Question: Can anyone tell me what this may be:
    It's screwed down to the walkway off the back of the pool room. It's right smack in the middle of the walking path if you go out the sliding door. I've tripped on it more than once.
    Looking forward to getting this pool back into shape & having some fun this summer!
    26k-28k enclosed IG rectangular gunite pool, Attached spa, Hayward cartridge filter, 2 HP pump, AC-1500 HP
    Feb 2008
    Denton, TX
    5,061
    Re: My new-to-me pool (PICS)
    I wouldn't put a whole lot of stock into what you read about the renovation company. My experience is that the happy customers aren't usually the ones taking the time to post about their experiences. They are usually off enjoying their pool.
    You really just need to take possession, top it off, and start things up. Then, you can see whats what. Have you ordered your test kit yet?
    Jul 2007
    Chicago, IL
    87
    If I were you, I'd ask the current owner to not attempt to clean up the pool water prior to the sale. Obviously, he doesn't know what he's doing and who knows what he'd throw in there to attempt to get the job done quickly.
    Follow the advice of the experts here and you'll have it looking good, all by yourself, the right way.
    Good Luck!
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Nov 2010
    South Central Kentucky
    283
    I bet that smells awesome...
    I'm excited to watch this one develop. Get a test kit, and read pool school. Ask questions here and you will have that pool looking great in no time.
    Looks like a sweet setup.
    The trip hazard may be a backwash outlet? Really not sure. Pics from the side?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    I found this online:
    http://www.1800pools.com/SP0681_Hayward ... utlet.html
    Seems to be what I have. No idea why it would be mounted outside???
    I am planning to order a TF-100 kit. I'm a noob when it come to pools. I likely will over test (I did when I first started doing reef tanks). Should I order the XL option or just order refills of certain reagents? I'm waiting a bit to order to make sure nothing is going to fall through on the house. i would hate to order $100+ in pool water testing do-dads & end up not having a pool to test.
    30,424
    Welcome to the forum. The TF-100 with the XL option is just about perfect to clear that murky pool. You shouldn't need anything else in the way of reagents.
    Best of luck with the purchase....that's a beautiful pool and we'd love to see some pics when it gets crystal clear.....it will
    38,305
    Get the SpeedStir add-on as well. It will make the frequent testing you are going to have to do much faster and more accurate.
    I was going to guess the trip hazard was the deck box
    May 2013
    Indiana
    16
    The trip hazard is an electrical junction box, There is one at our house that splits off the pool light circuit to run a couple flood lights as well. If you get someone that knows what they are doing they can take a 4 inch angle grinder and cut out just enough to install a flush mount box and seal the edges with silicone. It was in a very similar place at our house and after the second time of dropping a plate full of grilled food I about took it out with a sledge hammer till the wife stopped me.
    29,000 gallon kidney, 1, hp1.25 sf pentair, ta 100d sand filter plaster and fiberglass.
    Jul 2012
    SE Minnesota
    137
    Quote Originally Posted by Siamese
    Good Luck!
    I second that
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    The seller lives out of state now & isn't going to have much to do with the pool opening/ clean up. The seller is basically going to pay for the pool service company to come out & start the pumps up & give me a crash course on running everything. I assume it will be up to me to get everything cleaned up aside from the pool company dumping shock into it.
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    Maybe the sellers would credit back to you x amount of dollars towards the pool opening, which you can use to pay for that TF-100 test kit and lots and LOTS of bleach?
    Just wanted to post an updated picture. We are all moved in! I'm officially a pool owner!
    http://i.imgur.com/Oil08kE.jpg
    Jun 2010
    Michigan
    20
    Please post a few details on how it went from black to looking good.
    The picture may not be doing it justice so it's hard to tell if the water is clear or still a little cloudy.
    26.7K gal. vinyl (16x38 - 8ft deep end), 1 HP Centurion pump, 300 lb Sta-Rite Sand Filter, Blue Sapphire cleaning robot, TF100 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Certainly looks much better than what you initially inherited. If you can post additional pics, that would be great.
