Results 1 to 13 of 13
Thread: Appreciate all the help
    I just found the site and appreciate all the help. I will read more threads but just want a little help to simplify.
    1. Buy a good test kit.
    2. Buy bleach
    3. Buy Borax or pool acid.
    4. Constantly test you water and make minor adjustments using bleach, borax and possible baking soda.
    Is this pretty close? Anyone every get foaming from the bleach? Many thanks to all.
    23,000 IG plaster pool, hayward 2 speed 2.5 hp pump and 550 sq. ft. cartridge filter, SWG, Polaris 360
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: BBB for Beginners
    The bleach and test kit are good to buy now, the rest wait until you know what you need. I've never had to use borax or baking soda yet. Buy plan bleach with no additives and you shouldn't have a foaming problem.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Re: Appreciate all the help
    You won't get foaming from bleach without additives. You should only use bleach without additives or special added features. Some bleach with additives, for example "outdoors" bleach, contain detergent and will foam.
    Feb 2008
    Denton, TX
    5,061
    The test kit is most important. Borax is not required.
    Many thanks. I appreciate the help.
    I am in S FL with about a 13 x 26 oval pool. I guess 15,000 gallons. It seems like if I dump 1.5 gallons of chlorine and have a chlorine tab in the skimmer and 1 in the floater every week to 10 days - I should be okay without a lot of rain.
    Using BBB with a good test kit and testing frequently - will I need as much bleach or more? I always thought chlorine was just a more powerful version of bleach, I forget the chemical differences. Thanks.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,566
    The tabs could cause you a problem with CYA. I would not add anymore until you get your good test kit and can see where your CYA is at.
    The only want to lower CYA is to drain and add water.
    I only use the test kit and bleach! Oh and lots of smiles! LOL
    Thanks Kim Kats. I have been doing more reading here. My impression is the chlorine tabs are kind of like junk food. They drive up CYA and cause problems.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by FrankFL
    Never heard that one before, but I like it!!
    "Chlorine tabs are like Big Macs. They're fast and convenient, but every day multiple times a day is really, really not a good idea."
    I am going to order the TFP TF-50 test kit so I can do this right. I went to Leslies and had them run my numbers. FAC, CH,CYA was ok. TA and PH were slightly low. Cooper and Iron were ok at zero. My Phosphates were high at 400 ppb. The kid there could not remember if it was baking soda or soda ash for getting Phosphates down.
    They do not test for TDS or Total Dissolved Solids which I think may be my main problem. Last Week: I had algae from rain and the water was at the to edge of the pool. The overflow is clogged to try to keep a little extra in for the summer burn off of water. I put the vacuum hose at the bottom and was bleeding off water through my filter. It only bleeds off about 10 to 20% of the flow. I am borrowing a friends sump pump. This bleed off helped a lot. I only pumped out a little. The water is still cloudy.
    The only cure supposedly for TDS is supposedly draining the pool. Any ideas on TDS?
    My pool is on a deck that is somewhat elevated. I am on a canal. I think I may have slightly less hydrostatic pressure issues. I was thinking of draining it about half way with the sump pump at the bottom to hopefully pull most of the TDS.
    I will search the site here to see if there is more info on TDS. Many thanks to everyone for helping me out. I really appreciate it.
    30,426
    TDS is not relevant. No need to test for it or try to lower it.
    Mar 2010
    Spring, TX
    1,082
    If you can spring for it get the speed stirrer as well.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Jun 2012
    Howell, NJ
    977
    Phosphates and TDS don't matter, so don't worry about them. Also, I would stop going to that pool store, since they said to use either baking soda or soda ash to get the phosphates down. Soda ash raises TA and pH, and baking soda raises TA. Unless there is more complex chemistry that I don't understand, they do nothing for phosphates.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Quote Originally Posted by JohnN
    Thanks and thanks for the tips from everyone. I am going to order a TF-50 kit. I just wanted to get something going ASAP.
    The young guy seemed to be a little clueless. They were busy with a big sale. $1,000 something. I have given Leslie's plenty of money, so I had paid for that free water test. In the past, I bought with a Hayward pump, brushes, hose, filters and chlorine tabs which I will be getting away from thanks to BBB/TFP.
