Question about pH test results-
lulupalooza
340
Evans, GA
On 5/25 I tested and these where my results
CL 2
pH 7.2
TA 90
So I added 174 oz bleach and 54 oz borax (per pool calc) at bring pH up to 7.5- where I would like to keep it at
Tested the next morning 5/26
CL 5
pH 8.2 IT WAS DRK PINK!
Tested this morning 5/28
CL 4
pH 7.8 (is definately not as dark as it was!)
TA 100
My question is should I add m/a to try to bring the pH down to 7.5 or should I just leave it since it seems it's coming down gradually on it's own? I don't want to mess with TA- not so worried about it being 100, just don't want it to go up.
TYIA
Let the pH drop on its own. Each pool is an individual system and seems to find an equilibrium at which it wants to run. My pool wants to be at pH = 7.5 and so, when it gets there after startup, I leave it be.
AnnaK
AnnaK
I agree, as long as it stays within 7.2 - 7.8 . I've found with mine that if it's a tad low, I raise the TA by 10 until the pH stabilizes around 7.4 - 7.6 . Usually with TA = 110, my pH stays right at 7.4 .
