Thread: Question about pH test results-
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    On 5/25 I tested and these where my results
    CL 2
    pH 7.2
    TA 90
    So I added 174 oz bleach and 54 oz borax (per pool calc) at bring pH up to 7.5- where I would like to keep it at
    Tested the next morning 5/26
    CL 5
    pH 8.2 IT WAS DRK PINK!
    Tested this morning 5/28
    CL 4
    pH 7.8 (is definately not as dark as it was!)
    TA 100
    My question is should I add m/a to try to bring the pH down to 7.5 or should I just leave it since it seems it's coming down gradually on it's own? I don't want to mess with TA- not so worried about it being 100, just don't want it to go up.
    TYIA
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    If it's coming down on it's own, I'd let it keep drifting down until it holds steady again. Just test once daily and see where it lands.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    I agree with MikeInTN. As long as PH is between 7.2 and 7.8 and not headed rapidly towards leaving that range, then just leave it alone.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Let the pH drop on its own. Each pool is an individual system and seems to find an equilibrium at which it wants to run. My pool wants to be at pH = 7.5 and so, when it gets there after startup, I leave it be.
    AnnaK
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by AnnaK
    AnnaK
    I agree, as long as it stays within 7.2 - 7.8 . I've found with mine that if it's a tad low, I raise the TA by 10 until the pH stabilizes around 7.4 - 7.6 . Usually with TA = 110, my pH stays right at 7.4 .
    Intex 8110 SWCG
    "Fear the Schnauz!"
