Thread: Rusted wall on above ground pool
    Above ground has a good sized rusted area about 3 by 4 foot area is this fixable?
    24K gallons, IG, Kidney shaped, DE filter, 1.5HP pump, plaster/gunite, built in 1992.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Rusted wall on above ground pool
    Pics would help.
    can't get pics until tonite but its pretty bad, it goes all the way thru in one spot and the rusted area is probably 2 by 3 feet or so. I've read you can get sheet metal and cut a piece and rivet it over the bad area, thinking of trying that. Don't have the money for a new pool at the time.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Take a look at shadebuilder.com, Dennis writes about that type of fix. He used to be on here, and pool forum.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
