Thread: Pump Type for buried AGP
    Greetings all,
    I'm having my AGP installed in about a week. It is a 27 foot round, with a 52" wall. My pool will have a Hayward sand pump (not sure the model number yet.)
    I am going to sink the pool 24 to 30 inches in the ground.
    My question is: Can I still use an above ground pump, or do I need to switch to an in ground pump because the water won't be falling into the top of the pump / filter?
    I plan on putting the pump/filter within a few feet of the pool.
    Thanks!
    16x32 IG vinyl liner, Hayward Sand Filter.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pump Type for buried AGP
    Welcome to TFP!
    As long as the pump is still below the water level, an above-ground pump will work fine. If it is above (and has to suck water up to prime) you will need an inground pump.
    mas985's Avatar
    Pleasanton, CA
    11,737
    There are a few above ground pumps that are self-priming such as the Pentair Dynamo and the Hayward PowerFlo II. So if the pump is above water level, then you could use one of those.
    Mark
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I'm still working on getting mine backfilled but where I set the pump the pump is below the water line with no problems. The sand filter multi port is above the water line.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
