Thread: picking up lubricant/sealant from home depot/lowes
    Jul 2009
    Massachusetts
    188
    Hi, I was wondering whether these products could replace the pricier ones from the pool store.
    silicone lubricant for greasing o-rings
    DuPont 4 oz Silicone Lubricant
    http://www.lowes.com/pd_363779-39963-DS ... facetInfo=
    teflon tape for helping the seal on a drain plug
    Blue Monster 1/2-in x 119-ft Plumber's Tape
    http://www.lowes.com/pd_235767-33468-70 ... facetInfo=
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Re: picking up lubricant/sealant from home depot/lowes
    On the teflon tape, absolutely OK. For the silicone lube, it appears that might be a liquid style? I am more in favor of the gel style, which they should carry in the plumbing aisle - usually called Faucet lube or some such - it's a silicone lube that's a bit thicker than, say, petroleum jelly (which you should NOT use - it's bad for orings and plastics, and can get a bit rancid over time).
    Just my 2 cents -
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    Jun 2007
    New Jersey
    653
    I got this:
    http://www.amazon.com/PACK-Aladdin-T...cks+magic+lube
    I use it for other stuff. So one tube in the garage and one by the pool works great. $12 and I'm good for years with 2x5oz. The pool store prices are absolutely insane on crappy little 1 oz. tubes. Ridiculous.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2009
    Massachusetts
    188
    thanks i ended up getting the cheap teflon tape and the small little .5oz jar of silicone lub from home depot.. i purchased a similar lube from ace two years ago and found it really tacky, but the one from home depot seems to be a lot smoother and easier to work with.
    thanks for the feedback!!!
    Feb 2008
    Denton, TX
    5,061
    Good that your HD store has the silicone lube. My only source for it is pool stores. All I can find outside of the pool stores is the aerosol spray and that doesn't cut it.
    Jul 2009
    Massachusetts
    188
    Quote Originally Posted by 257WbyMag
    fyi - it was totally in an obscure place .. hanging on a hook in the plumbing section alongside connectors and other small pipe attachments. no other lubricants there.. in a different aisle from the teflon tape too.
