Thread: Total rebuild or component by component?
    We have a hot tub that we bought about 9 years ago. It is a sunbelt with gecko components. We let it sit empty last year and I was dead set on giving it away but alas the wife wants to keep it. When I last drained it it wasn't heating. I filled it a few days ago and turned on the breaker and it tripped almost immediately. I tried this twice. I assume it is the heating element as the studs coming out of the top are extremely corroded. The control board is clean with no signs of anything burning up.
    Now for my question. If it were you with a 9 year old spa would you buy just the individual components needed to get it running or a whole new pack (circuit board, heater and controls)? It looks like I could get a new pack for about $500. Or I could get a $30 element and start tracing/replacing from there.
    What would you do and if you went with a new pack what brand would you look at?
    18' x 36' saltwater inground vinyl pool
    Re: Total rebuild or component by component?
    Well. The pump is definitely tripping the main breaker almost instantly. I disconnected the blower and pump. The display reads temp and has a code flashing. I guess I'll check the pump next
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I did component by component. I found a local hot tub guy that knows his stuff and was reasonable. I've replaced the control board, heater tube and pump...over past two years, but now were good for anothe 5-7 we think. I'd do it all at once if you can afford it and like the tub.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    Southeast
    78
    Mine was nearly a total rebuild. New ozonator, cover, circuit board and control panel, a generator and reinforced base. It probably cost the price of a new one but the cost of an entirely new deck would have also been pretty darn high, too.
    24x32 feet, In-ground, Saltwater, Gunite pool (under construction)
    Jun 2012
    Long Beach, NY
    1
    8 months after Sandy destroyed every component of my spa, I got it all reworked this past weekend. New pump, blower, pack/heater and ozonator. Just over 8 bills and a short afternoon of hooking it up
    Mike
    14x28 vinyl, 13k gal
    Hayward 4800 DE with cellulose
    1.5 hp Hayward pump
    Polaris 360
    Homemade fountain
    ThermoSpas Chesapeake
    Lynx 30" Pro Grill w/natural gas
