Thread: Some bleach??
    Mar 2013
    CT
    353
    Some bleach??
    Waiting on my Taylor test kit which will be here Sat. I won't have a chance to open the pool and run water tests until Thursday. When I do pull the cover off on Thursday, should I at least put "some" bleach in the water right away to help fight algae right off the bat?
    I will be posting the results here and following your guys advice but it might be a day or two until I can add read the responses and add chemicals. From what I have read algae can grow pretty quickly and I figure maybe putting some chorine in the pool right off the bat might help prevent any immediate growth.
    Or - is that just a total waste of time and bleach?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Some bleach??
    If when you open, your water is fairly clear and if you have the OTO test kit (the one that has a view tube usually attached to the ph view tube), then I would use that and get your FC (TC in the case of the OTO chlorine test) up to 3 ppm each day.
    Re: Some bleach??
    I agree with linen and would also check pH and adjust that as needed.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
