Thread: Help me decide pool location/ layout
    Jan 2013
    Southwestern Ontario, Canada
    30
    I'm putting in an oval 15 x 30 "on-ground" pool that will be sunk in the ground.
    Having trouble deciding on where exactly to put it...
    My lot is very narrow, and there won't be a lot of privacy (new subdivision). Currently there is nothing except a floating wood deck (I might remove it and add a covered deck attached to house). We will be fencing in the pool (that's a fence on the drawing, not decking). Should i keep the equipment at the back of the lot (to reduce noise near the patio?). I left a bit of room between patio and fence of pool for a small firepit area, is that a bad idea? Does the pool seem too separate from the seating area? We live in Canada, so there will be times when we want the kids to be able to be on deck etc without being able to get into the pool.
    Jan 2013
    30
    Re: Help me decide pool location/ layout
    The drawing is rough but if having trouble understanding let me know. I would really appreciate some advice!!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Nothing strikes me as too bad with the thoughts. You might save some space by sliding the pool and fence over to the side boundary line if you can. I agree with having it fenced separately with some extra space near the house not inside of the fence. I don't see many other placement options given your constraints.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Jan 2013
    30
    Thanks, it's mostly the space between pool and patio that i wasn't sure of. Seems to be a good place for the firepit though.
    I can't move pool any closer to side property line (shown 5' away). And there is a drainage easement along the back property line so I can't move pool shed any closer to the back either.
    You're right, there aren't many options!
