Thread: Pentair UltraTemp Heat Pump RPM needed to heat pool?
    May 2013
    Southern IL
    42
    Hello. As I've said before I'm new to being a pool owner, I've read through the manual and didn't see any recommendations for this question. How many RPM's should I have my Pentair IntelliFlo VS pump set to to efficiently allow my Pentair UltraTemp Heat Pump heat the pool 32K gal pool? I thought the pool builder told me like 1300RPM, but I had it at that and it turned off because Low Flow, so I bumped it to 1400RPM, and 1500RPM and same thing. The pool is still being cleaned out from all the concrete mess that got in there and junk from before automatic pool cover was installed. I understand that maybe with all that junk being filtered through that maybe it's not getting all the flow that it might when clean. So, I don't know if once the pool is cleaned and chemicals added that the heat will work at a lower 1300RPM or what I should set it for?
    Thanks for any input.
    30,200 gallon. IG - 20 by 46". Vinyl liner. Sand filter.
    Pentair Intelliflo Variable Speed Pump.
    Built April/May 2013.
    Empress Royal Spa
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Pentair UltraTemp Heat Pump RPM needed to heat pool?
    You will probably need to hit 40 GPM which may be closer to 2000 RPM. I would just keep increasing by 100 RPM until there is no low flow error.
    Mark
    May 2013
    Southern IL
    42
    10-4. I figured with all the junk in there, I'd just bump it up strong until it's cleaned out. Plus, I'm at work today so can't check it every little bit and I'd like to it to start warming up . Tomorrow, I'll go back to the 100RPM increments. I have no idea how long it typically takes a pool to warm up. The temperatures are slowly raising and staying steady here in Southern, IL
    Empress Royal Spa
    ANdyc83, I'd appreciate hearing if you are happy with the Pentair heat pump. I have about the same size pool and was considering going with a larger unit from another manufacturer... but I hate to lose the serial interface with IntelliTouch. Does the 120K BTU get your pool up to temp OK?
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    May 2013
    Southern IL
    42
    jtech1: So far I love it. We have had a drastic change in weather. Currently 55 in Southern, IL. It was probably colder temps over night. I checked this morning and had the heat pump set to 85 (plan to have it around 90 but new the colder weather was coming and we wouldn't be in it, so why waste the energy), the current temp was 83 and the pump was running. So, it was close to keeping up but I'm sure with the colder temperatures in the 40's overnight it just couldn't quite keep up, but when summer starts really kicking in I don't think it'll have a problem. I should also note I have an auto cover so it was covered overnight.
    Empress Royal Spa
