Results 1 to 9 of 9
Thread: dura glass pump question
    Hi, I am a new pool owner and I have dura glass pump. I do not know when it was installed. What is the difference between pre and post 1998 dura glass I pump? Thanks, Kris
    12,750 IG plaster/pebble. 1 HP uprated Duraglass pump. Cartridge filter.
    22,550
    Re: dura glass pump question
    Looks like the seal is about the only real difference.
    Which seal? how do recognize which pump i own? Thanks, kris
    mas985's Avatar
    Pleasanton, CA
    11,737
    Welcome to the forum.
    The seal kits are different and you can see below that there is a copper insert in the seal plate (see 7b) for the pre-1998 pump.
    Mark
    Thanks. So I guess I have to disassemble my pump to know for sure?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I am not sure if there is an external clue or not but it is pretty easy to take apart the wet end.
    Are you shopping for a seal kit?
    Mark
    Yes I am. I just opened wet and but I do not know how to get part #10 pulled of the shaft?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here are some instructions for a motor change which has the part about removing the impeller:
    http://www.poolsupplyclub.com/p-4126-st ... anges.aspx
    But you should be able to see behind the impeller after you remove the diffuser.
    Mark
    Thanks for the link! I do not see any copper. I guess it is post 1998. Great forum. Really appreciate all your help. Kris
