Results 1 to 18 of 18
Thread: Wrinkles
    korinian's Avatar
    Claremore, Oklahoma
    16
    Wrinkles
    We've had a very wet winter and spring in Oklahoma. I uncovered the pool this last weekend and it was horrible. Algae was everywhere... thick and nasty. Finally finished getting everything under control yesterday. Nice and clear... however, I've got some wrinkles in my liner. The liner is 3 years old and was flawless as of last year. I'm guessing that the wrinkles are a byproduct of the ground water rising. They are in the shallow end on the floor of the pool. My question is will these damage the liner if I do nothing AND are they as big a pain to remove as I think they will be. Thanks for any help.
    50,000 gallon vinyl IG, Hayward 1.5hp Pump, 300lbs Sand Filter located in Oklahoma.
    - Korinian
    A high water table is the most likely cause. The wrinkles don't normally cause significant problems. They can be very very difficult to get out.
    korinian's Avatar
    Claremore, Oklahoma
    16
    Wrinkles
    Well, I spent about an hour in the shallow end of my pool with a toilet plunger. Not the best opening line in a message, but after carefully working the wrinkles slowly back towards the pool walls I've successfully removed 8 pretty bad wrinkles. I'm about halfway done. It worked great. Just thought I'd give an update. I didn't have to drain any water. Thanks to the 2 forums I frequent for pool info. That's where I'd found the tip about the plunger.
    - Korinian
    Re: Wrinkles
    Quote Originally Posted by korinian
    That's FUNNY!!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Share the tip please. What's the process?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    korinian's Avatar
    Claremore, Oklahoma
    16
    Quote Originally Posted by AnnaK
    This is from someone else, but's it's what I did.
    "What if your pool is full and there are wrinkles in the liner? If there are only a few small wrinkles, you may be able to remove these by using a toilet plunger. By plunging around the wrinkle you can spread out the liner in that area thereby removing the wrinkle. Do not plunge directly on the wrinkle but rather just above, below, or to the side."
    I had some pretty long wrinkles but this process worked for me. I would carefully press the plunger beside the wrinkle and gently pull it up and in the direction I want the extra folded liner to go. Then I'd use my toes to flatten out any residual wrinkle. I was really surprised when it worked. Most of the wrinkles I worked toward the wall because I figured that's where the extra lining came from originally. Some of the wrinkles that look like spokes on a wheel... 3 or 4 legs I worked in all directions. It takes time but the ones I worked on yesterday are still gone. I don't know if they'll stay gone... but the solution was cheap and easy.... just time consuming.
    - Korinian
    That tip really rocks. That is one tip that I will remember forever....more than one use for a plunger. Thanks
    [i][color=#BF0040]27' x 52"....1.5 HP hayward pump 200lb sand filter.....finally building our deck :)
    AnnaK's Avatar
    Jul 2007
    1,134
    Thanks a lot! I think I'll give that a try.
    AnnaK
    korinian's Avatar
    Claremore, Oklahoma
    16
    Good luck! Let me know how it turns out.
    - Korinian
    Jul 2007
    Northern NJ
    299
    Yes, I will try that too. We had our liner replaced in April and by the time all the water was in, we had wrinkles.
    Thanks!
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Canada
    29
    Re: Wrinkles
    So, I see by your bio that you have an inground pool?
    Is there any particular type of plunger for this job?
    anyone who has tried this with ingrounds.. I see a couple of different styles of plungers out there.
    I don't have the standard one ( which is a smaller circle bellow a larger one) but rather a skinny but long one that reminds me of a bee-hive that has been squished througha hole
    ( lol - does that make sense?)
    I may give this a try & I'll let you know how it works out
    korinian's Avatar
    Claremore, Oklahoma
    16
    Re: Wrinkles
    I used one that looks like this:
    The outside skirt got shoved up into the plunger 2 out of 5 times. Although, the rubber towards the bottom has a thinner wall than the top and was probably more gentle on the liner. If I were to do it again I'd probably try a different one and see how it works.
    - Korinian
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re:
    Quote Originally Posted by heatmisr
    Thanks!
    Nichole, what no warranty on the install
    Luv& Luk
    -Ted
    Jul 2007
    Northern NJ
    299
    Re: Re:
    Quote Originally Posted by waste
    Thanks!
    Not for wrinkles. However, I did think about calling them about the uneven bottom. My biggest problem is the drain and refill that would be needed. I really don't have anywhere to drain that much water at one time and I take a hit on my sewer bill for the refill.
    Any suggestions?
    Nicole
    21' AGP (10,400g)
    Mar 2007
    4,160
    Re: Wrinkles
    Sure I've got suggestions If they won't cover the wrinkles (which they SHOULD!!!!), woof about the uneven floor and they'll have to drain the pool to fix the floor - at that point, once the floor is fixed, just make sure they don't leave wrinkles when they reset the liner If you want some tips on keeping them honest on not leaving wrinkles this time, I'll gladly help you - I can't believe they don't warranty for wrinkles on a new liner
    Luv& Luk
    -Ted
    Jul 2007
    Northern NJ
    299
    Re: Wrinkles
    Believe it. It was clearly written on the receipt. At the time, right after they left, it wasn't a problem because there weren't any. If I knew then what I know now........ It took 3 days to fill the pool. When it was done filling, that's when all the wrinkles and craters appeared. DH said it was completely smooth when they dropped the liner, so I don't know what happened. Could it be because it took so long to fill the sand had time to shift?
    Nicole
    21' AGP (10,400g)
    Mar 2007
    4,160
    Re: Wrinkles
    Well, I suppose it could be, but I'd put my money on the sand not being fully compacted before the liner went in and the weight of the water settled the liner/ floor where the sand wasn't @ 95%+ compacted If the sand was properly compacted and troweled, you shouldn't have seen more than a small dip or bump 'here or there'
    You got scr&wed on your warranty! The floor should be ~ level and NO wrinkles in the liner!!!!
    If I can help as you try to deal with them to make your pool right, feel free to call upon me
    Luv& Luk
    -Ted
    Jul 2007
    Northern NJ
    299
    Re: Wrinkles
    Thanks, waste.
    I'm going to throw the glowbuoy in tomorrow night and take some pictures. (gotta vacuum first) The craters show up real good with that thing in.... I'm going to start a new thread since I unintentionally hijacked this one....lol.
    Nicole
    21' AGP (10,400g)
