Thread: Intex SWG with copper
    Jul 2011
    Webster,Wi
    59
    I'm in the process of getting the pool set back up, we had snow flurries on May 7th real nice! I was thinking of disconnecting the copper element from the pump, can you unscrew the 2 probs that are screwed into the copper bars and then screw the original lead back on without any problems?
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex SWG with copper
    Easiest thing to do is just leave the plug unplugged. The posts and copper bars seal up the post holes.
    Jul 2011
    Webster,Wi
    59
    I was able to unscrew the posts and just screwed the lead back on just to neaten it up some, shouldn't be any problem?
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Just unplug that cable on the outside connected to the copper bars and you'll be fine. It might put up a bit of a fight, but it'll come off. Keep the copper bars in and the nut screwed on because that's what seals it.
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
