Results 1 to 8 of 8
Thread: Dumb question, pump strainer basket drain
    Do all pumps have a drain plug under the strainer basket? I can't find mine. I have a suction side air leak leading to bubbles in my return. Also pump lost prime after a few hours turned off. Might be my basket lid, but I was trying to find the drain plug and didn't seem to be one on the bottom.
    32000 Gallon 18'X40' Rectangular Gunite pool. Pentair 60sqft DE filter. Electric heat pump. Aquamatic Pool Cover.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Dumb question, pump strainer basket drain
    bolleat:
    The drain plug on my pump is located on the bowl where the strainer basket is, toward the bottom but on the side - not under it.
    Thanks I'll look in the morning. I think it was getting to dark when I tried to find it, maybe just didn't see it.
    It most likely has a drain plug. What make and model?
    Support the site
    Great. Found my drain in the front of the strainer basket. Ok it is sealed tight, now I need to figure out why I have so much air coming out of my returns. It started after i cleaned my strainer basket so my guess is it must be the top.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by bolleat
    That is by far the most likely, especially since you just messed with it. Be sure it's lubed up good, the O-ring isn't cracked, and there's no grit or bits of grass in the way.
    [center:bi8bnhar][youtube:bi8bnhar]vtSmfws0_To[/youtube:bi8bnhar]
    Round up the usual suspects: low water level, stuck weir in the skimmer, loose drain plugs on the
    pump, poor seal on the pump strainer basket, and leaks at the fittings, especially any couplings.[/center:bi8bnhar]
    Thanks, gotta get me some lube. Without fresh lube will it usually leak? My guess is since I didn't have any lube I couldn't get a good tight seal?
    Jun 2012
    Louisville, KY
    266
    The o-ring on the pump basket should be well lubed and able to make a good seal. Clean the pump lid and make sure there is zero debris in there or on the pump lid. Any little bit is enough to make it not get a good seal and let air in.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
