Results 1 to 14 of 14
Thread: Another Newbie Here
    May 2013
    Atlanta, GA
    27
    Another Newbie Here
    Greetings all,
    Happy to be a member of the site. I was a bit intimidated with managing my pool last year after we got it.... and didn't pay much attention to it other then throwing a sack of shock and a chlorine puck in it every now and then. I closed the pool and when I opened it 10 days ago I had a green swamp (sorry no pics). It was complete with tadpoles, frogs and who knows what else. There was a lot of pine straw on the bottom. I also had to clean the impeller as it clogged up with pine straw.
    For the past week - I've been added 2 lbs of shock every night when I get home from work (at midnight). I still can't see the bottom but I think I'm moving in the right direction. I ordered and received the TF100 test kit and here are the numbers as of this morning:
    PH 6.8
    CYA 0
    CH 150
    TA 40
    FC 6
    CC 1
    TC 7
    Any advice would be appreciated regarding those numbers.
    28' round Doughboy AGP (23,000 gallons) 7.5' deep end
    Aquaview sand filter
    Hayward 1.5HP pump
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Another Newbie Here
    - gotta get CYA up
    - gotta get Ph up
    - gotta get TA up
    - looks like a shock might be in order
    Bit of work to do there, are you using pool calculator.com?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,027
    Yeah, what he said.
    Welcome
    May 2013
    Atlanta, GA
    27
    Been doing 2 lbs of shock every night. Should I start shocking during the day as well .... and add bleach ....etc.
    I'm new to the calculator as well. I'll check it out. Looks like a fantastic tool! I'm taking the bull by the horns this year and am actually enjoying the new knowledge and challenge.
    Hayward 1.5HP pump
    38,305
    What kind of "shock" are you using, we prefer liquid chlorine / bleach.
    It is either adding CH which you do not need, or CYA which you do need some of.
    Read the articles below:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    Shocking Your Pool
    May 2013
    Atlanta, GA
    27
    I think it's aqua chem and the active ingredient is Dichlor. I bought the stuff at BJs. You're right, I don't need to add any more CH. I'll get some 8.5% bleach at the store this evening.
    Hayward 1.5HP pump
    Richard320's Avatar
    Jan 2010
    19,027
    Quote Originally Posted by unixfreak
    Dichlor adds CYA - lots of it! And since you need both... Just don't try to add all the CYA at once, or you'll shove FC through the roof.
    Check out "Effects of Adding Chemicals" at the bottom of http://www.poolcalculator.com/ Be sure you enter your pool's size at the top.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Remember that CYA takes a bit to show up in your tests, if you added stuff with a CYA component to it don't forget to factor that in if you go to add more or else you can end up with too much.
    Definitely read, and re-read pool school a few times, that will prevent you from spinning your wheels, especially if your going to shock the pool properly.
    May 2013
    Atlanta, GA
    27
    Last night I added 8 lbs of borax and 10 lbs of baking soda and tested this morning. Here are the numbers:
    CL 0.5
    CYA 0
    TA 130
    PH 7.6
    The glaring number to me is the CYA. I was wrong about the type of shock that I was using. It's main active ingredient is calcium hyphochlorite. The brand is hth "super shock it".
    The chlorine pucks that I have are trichlor-triazinetrione. I put a couple of those in the skimmer today as well as a bag of that shock. I also swept the pool.
    Thanks so much for the help.
    Hayward 1.5HP pump
    38,305
    It is going to take too long to get the CYA up using a couple pucks at a time. Best to add CYA separately up to 30ppm to protect the FC from the sun.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    May 2013
    Atlanta, GA
    27
    Any recommendations on what stabilizer to purchase? 4 lbs. looks like a starting point.
    Hayward 1.5HP pump
    Richard320's Avatar
    Jan 2010
    19,027
    As long as it shows 98% or better concentration and no copper, whatever is cheapest.
    30,424
    It's all the same stuff pretty much. It should be at least 96% CYA but most are that or greater.
    May 2013
    Atlanta, GA
    27
    Numbers are looking better.
    CL 2
    CH 100
    PH 7.2
    TA 110
    I'm still not seeing the dot disappear. So I'm assuming that my CYA is either not giving me a reading yet ... or it's close to 0. I have not put any stabilizer in it yet. I'm shocking at night with 65% cal-hypo and leaving a trichlor puck in the skimmer. I'm seeing the bottom for the first time although it's still a little cloudy. Kids are swimming in it and having a blast.
    Thanks for all the help.
    Hayward 1.5HP pump
