Results 1 to 7 of 7
Thread: Confused in Seattle
    May 2008
    Seattle, WA
    Confused in Seattle
    So, I have been testing with the Taylor K-2006. For fun, took a water sample into Aquaquip (only pool store around) and here is what they get for readings:
    Ph 7.8 (I get 7.6)
    FC 3.2 (I get 5.5)
    CC 2.2 (I get .5)
    CYA 59 (I get < 20)
    So of course they wanted us to buy 5 bags of "Burn-Out" to bring down the CC.
    I don't get it---how can my testing be so different from theirs? Has anyone else seen this?
    AG 18x38x4 (16,000gals), sand filter
    whoozer's Avatar
    Apr 2008
    Acton Maine
    Well before you go putting a bunch of stuff in your pool look at a couple of things.
    1) Make sure you reread the directions from your kit and you are following its procedure.
    2) After being sure of procedure try retesting with your kit. Testing has a few common factors that are important, repetition,consistency,reproducable numbers.
    Sometimes you don't know at some pool stores. If the person testing has just learned themselves they are just as apt to mess up as you. As long as you have followed the kit instructions and are sure the integrity of your kit is ok. I would stick to your numbers. Others may disagree but I think that is the point of getting your own comprehensive kit. To DIY and not rely on someone else that is yacking on a cell phone while testing your water at the pool store
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator ,
    I can't speak about the employees at your local PS, but even the best computer based test systems are not reliable considering the fumbling unknowledgeable 12yr olds that work at my local PS. I would always trust your own results. Especially when using a nice test kit such as yours.
    2003 Coleman MAAX Collection Model 706 - 400gal
    Nobody cares about your pool and water like you do!! Always trust YOUR numbers!!
    8000 gallon 20' x 48" round vinyl frame pool, 12" sand filter (don't have the specs on the pump), TF100 test kit
    Handy Links: PoolMath, TF-100 Test Kit, Pool School, CYA-Chlorine Chart
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    I've had the same large variances with pool store test vs TF-100 test. I have chosen to go with the TF-100 results. I add chems based on my own test results and my water speaks for itself.
    — AnnaK —
    12,000 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Butterfly's Avatar
    South Carolina
    Re: Confused in Seattle
    Quote Originally Posted by Seattlevue444
    I don't get it---how can my testing be so different from theirs? Has anyone else seen this?, yep!
    ALWAYS trust your testing over any pool store,........ unless it is the pool store where our obi-wan Waterbear works part-time in Florida and he is doing the testing!
    You're done SLAMing when:
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    The test results I have gotten using my TFP kit vs. the pool store were even more varied than this! I showed (and still do!) a CYA of 100 whereas they said it was only 30! My FC was over 23 with my test kit and they said it was 3!! I wouldn't trust a pool store's numbers for any amount of money (except, like jj says...unless it were you waterbear! ) It's like I have read on this forum somewhere before ....the pool stores are in business to sell you chemicals. They aren't near as concerned at getting your pool chemistry correct. That would cost them profit! As I have seen so many your own numbers!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Pentair Booster Pump
    Letro Platinum pressure side cleaner
    Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
