Thread: White Film on Surface
    The film is back. I have shocked the pool twice with sufficient bleach to raise the chlorine level to over 20 (by serial dilution with distilled water, OTO test). (My test kit has been ordered). Water is otherwise clear. All other parameters that I can test with the 5 way HTH are OK with the exception of CYA = 80.
    Are there any enzymatic cleaners that might be effective?
    Sacramento CA
    33,000gal, IG, circa 1970, (now) fiberglass over plaster, pac-fab paper cartridge, 1.5hp pump, polaris 280 (inoperable, UV damage) with booster, solar heat (inoperable, leak in powermat), skimmer (inoperable, line clogged & possibly fractured under concrete), main drain inoperable (long standing problem), jury rigged deep intake, skimmer line work-around in progress.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Re: White Film on Surface
    Are you sure it's not just pollen? Are there any big fires nearby dropping ash everywhere? Go look at the car, the patio furniture, and the windowsills and see if they're coated with anything similar.
    Another possibility is that it's cheap algaecide foaming up. Chlorine will eliminate it. Just be patient.
    No it is not pollen or ash. It is oily or wax like. There has been no suntan lotion or other oils introduced into the pool.
    Sacramento CA
    Richard320's Avatar
    Jan 2010
    19,043
    I know there is a product called "Pool First Aid" that contains enzymes that get rid of oils. I have no experience with it personally.
