Thread: ClevaChlor no power
    ClevaChlor no power
    This morning there were no lights (presume no power) on my 8 year old ClevaChlor RPC30 system. Before I start dismantling anything are there any fuses or other 'typical' failure points on this system?
    If the problem is more than a loose wire/fuse. Given the cell is 8 years old, nigh on impossible to replace (at least for less that $800), does it make sense to just change the whole system? If so what's the best recommendations - my system is all exposed to the southern california elements, so gets plenty of direct sunlight?
    Should all the replacement systems (Hayward, Circupool, Jandy) just use the existing wiring and simple cell re-plumb? Anything to avoid?
    Thanks for the help,
    Mark
    Built 2005, 15k IG Pebble, bean shaped + spa with spillway, 7.5' deep end, 30" shallow
    1.5" skimmer & 1.5" navigator lines, 2" at pad, 2nd story solar heat, 2.0 hp FloPro VS-FHP2.0 pool pump, Sta-Rite S8M150 Modular Media Filter, Heater (don't know - don't use because of Solar), Chlevachlor RP30 salt cell, 2hp spa Sta-Rite booster for spa
    Jandy RS2/6 One Touch Rev L, 4 relays in use, 2 spare AUX but no relays
    22,553
    Re: ClevaChlor no power
    With that old a unit I wouldn't fool with it too much. All the units will use the same power wiring as you have now as long as you get one with the correct voltage.
    Well a fuse fixed it for now. Let's see how long it lasts...
    Thanks
    Mark
