Results 1 to 12 of 12
Thread: The pool cleaner ($388) vs dolphin dx5 ($750)
    Hi,
    Down to these two. Is dolphin worth the extra spend?
    Tia
    37x20, 28,300 gallon gunite, irregularly shaped, hayward 1.5 super pump, hayward 4820 DE filter, northeast geo
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: The pool cleaner ($388) vs dolphin dx5 ($750)
    You are comparing a suction only cleaner to a suction + Electric model. The suction + Electric model is always going to clean better....is it worth it...I think its a personal opinion. I've never had issues with my pool and a suction cleaner myself.
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    Why will it be better? I'm missing what the electronic cleaner is going to do that the suction cleaner is not. Also, I see u have a Hayward nav. How do you like it? Lot of negative reviews on the cost of maintenance for the nav, what's been your experience?
    May 2013
    Kentucky
    29
    Do you have a dedicated suction line installed in your pool? It seems to me that if you have already spent the money to install the dedicated suction line the Pool Cleaner is the way to go. It has pretty good reviews and will likely require much less (and cheaper) maintenance than the robot would.
    20 x 45 ft Roman Lazy L, 28k Gallons, Vinyl, Pentair Triton II TR-100 Sand Filter (600 lb), 1.5 HP pump + Booster pump for Polaris 280, Hayward Gas Heater H300, Hayward T-15 SWCG w/ AquaRite digital controller
    I have two skimmers, I called the company and they said it should work. Actually I have a broken Polaris pump and a 280 that needs service. Cost to replace booster is $500-600 so I'm looking at alternatives.
    38,475
    The Zodiac MX-8 is also another suction cleaner that gets good reviews ... and with rebate only $300.
    I personally had it narrowed down to the PC2 and the MX8 if I go with a suction cleaner.
    the mx8 reviews on amazon are a little weak. I'd probably look at the g3 over the mx8. What was your experience with the dolphin?
    38,475
    Liked the Dynamic a lot (has split rollers and 2 motors, so it can actively turn), seems to be dead after 3.5 years. Then was considering ordering a suction cleaner to try and save some money, but FIL had the Diagnostic that he did not like and gave it to use to use (or maybe keep). It has a single motor, moves slower, keeps wanting to float and seems to get stuck in pattern. It work fine for being free, but if I bought again, I would want the split rollers.
    Kind of gets old putting the robot in and out of the water, but with the suction side you would end up having to do the same if you did not want to be swimming with it.
    I was basing my suction choices on the reviews / discussions I have seen here, so admittedly did not do a lot of research after getting the other robot.
    I called the manufacturer of The Pool Cleaner and they don't suggest you swim with it. So you have a pool cleaner with 40 foot of hose that you have to horse out of the pool and, I guess, lay on the side of your pool. I suppose this is true with any suction cleaner. With a robot you (may) have a caddy and your pulling wire instead of hose.
    dunno, If I spend $750 for a 3.5 year robot life I'll be very disappointed. I have to take a look at my credit cards, maybe one of them will add some extra protection.
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Quote Originally Posted by vinouspleasure
    Actually upgraded to the mx8 recently...haven't updated my signature line yet.
    38,475
    Yup pretty disappointed in the life. I actually got mine from Costco, but they do not seem to have had any robots for sale the last few years.
    I have not taken the time to see determine exactly what is wrong with it and whether I can fix it myself.
    I checked costco too. bjs has an aquabot but I just don't have enough data on the brand or their model. It looks like my credit card co offers and extra 12 months of coverage which would cover me for 3 years.
    dunno, I'm going to make a decision over the next 2 weeks.
