Thread: Auto Pool Cover Price
    Jul 2011
    St. Paul, MN
    244
    I've received a couple of quotes for installing an auto pool cover for my inground pool and am wondering if the prices seem reasonable.
    I have a 20'x40' vinyl oval shaped pool. The estimates I have received are both about $10,000 for the cover and install of the cover. Both are for CoverStar brand covers. The estimates include cutting out decking and installation of the reel, rails, etc...
    The estimates don't include the electrical or any concrete work if that is need.
    I am in Minnesota.
    Sound reasonable?
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Auto Pool Cover Price
    Yes it does, mine was $12k last summer. Worth every penny.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Your pit will need a drain, where will it drain to, and who will trench in the drain and repair landscaping?
    18'x43' Sport Pool
    Jul 2011
    St. Paul, MN
    244
    A couple of additional questions:
    1. Thumbs up or down on the CoverStar brand?
    2. For my install, the vault for the pool cover will be between the deep end of the pool and the diving board. The install of the pool cover will cause the concrete that the diving board is on to be completely separated from the rest of the pool deck. Any concerns about this?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Didn't notice you have an oval pool. So your rails will be installed in your pool deck. I'm not familiar with how the cover runs in those types of tracks, assume it's same as mine.
    Your installer will be the most important part of the equation. If my pool builder had installed Aquamatic i might have considered them, but he only had experience with coverstar.
    I would ask a bunch of questions regarding the cover rubbing on the pool deck as it is opened and closed. I would be afraid the cover would wear very quickly rubbing across the concrete. You can't easily see the underneath side of the cover to monitor this either.
    Couple of comments....
    Your pool will stay a lot warmer.
    You'll use less chlorine due to reduced stuff getting in your pool and reduced sunlight exposure.
    You will have to do maintenance on it, cleaning out the pit couple times a year. Scrubbing the cover with a citrus cleaner. Treating the cover with 303 aerospace protectant. spraying some food grade silicon on the pulley's.
    You will have to keep/put a pump on the surface of the cover when it's going to rain to pump the water off. It can fill up with water and be okay, but it takes a long time to pump water off. You aren't supposed to operate it with water on it, too heavy for motor.
    You can walk on it, in fact you could have a party on it. (Assuming it's installed in a similar manner to mine). If you couldn't, what would be the point from a saftey aspect?
    You'll want to blow the leaves off the cover during the fall to avoid them sitting on there and staining it (stains did come out for me this year, looks new after my cleaning).
    Depending on the pit cover you choose, you may be able to walk on it, or may be advised against walking on it.
    All said and done, i like it because in this order....
    Properly pumped off it keeps kids safe
    It allows me to keep my pool hot and extend the season
    I've never used a leaf net.
    I've never shocked (on purpose).
    Any questions just ask.
    18'x43' Sport Pool
    Nov 2011
    Moberly,MO
    1,010
    faby ask for the stainless steel eclipse version of the coverstar. This will tolerate a salt system. Coverstar has an excellent setup. If possible ask for references to check out your installers.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
