Thread: Repurpose Intex 2650gpm/.95hp pump
    Apr 2012
    Northern VA
    1
    Hi there!
    I called up Intex regarding a problem with the pump (manf rating 2650gph/0.95hp) that came with the 56681EG Pump+SWG+16in sand filter set. Much to my surprise they sent me out a whole new pump and did not require the old one to get sent back.
    The problem was minor and I should be able to resolve it myself, so rather than toss the old one I would like to use it.
    Any suggestions on what I could do with the spare pump? Is there a way to disable the plugs (other than the flow sensor perhaps) so it can be run as a normal pump and not throw errors regarding the SWG and/or copper gizmo?
    Would I be better server having it pump in to the sand filter so it can run when the SWG is not cycling? Or would something for a fountain and/or dedicated vacuum be better?
    FWIW, I have hard plumbed my existing setup and added a Hayward skimmer thanks to all the help here.
    22,548
    Re: Repurpose Intex 2650gpm/.95hp pump
    I would use it for a fountain and just disconnect everything but the pump.
