Thread: how to deal with all this stuff falling
    I have been cleaning out the skimmer at least twice a day because of all the stuff falling in the pool. Does anyone have a solution that will keep the skimmer from filling up totally with this stuff and practically preventing flow all together? I have to be away for about a week and will probably cover the pool with the solar cover but I would like to keep some circulation going also. I am afraid that I will burn up the pump if it gets stopped up. Thanks for any ideas.
    27 foot round above ground
    22,550
    Re: how to deal with all this stuff falling
    There have been a few posts about putting a soft drink bottle case in front of the skimmer and covering it with plastic screen. You could also install a Pool Skim. It wouldn't totally eliminate the problem but would catch enough stuff to help a lot.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    If you are going away you could always, if your pool is setup for it, throttle the skimmer down and make the main drain work more. This way if the skimmer did get filled with debris, the main drain is doing all the work.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
