Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: Still green after shock, floc, and pool first-aid?
    Hello fellow pool owners,
    As a rookie to the site, please bear with as many stupid questions/things I'm about to say:
    My wife and I purchased our first house last year in July. Having a pool, we were really excited about the prospect of having it look nice. After scrambling all summer to keep up, we finally closed and winterized the pool. Being the broke young married couple, we could not afford a cover at the time so we left the pool uncovered (first mistake).
    Opening the pool last weekend we are realizing our errors. After scooping a ton of leaves out and still having some at the bottom, we dumped 2 bottles of black algaecide, 15 bags of shock, 1 pool first aid bottle (64 oz.), and a bottle of flocculant. The numbers we received back from Leslie's testing say our water is perfect.
    Howevah, we are still dealing with a very green pool and lots of algae. So much that we can't see the shallow or deep end of the pool. We keep pulling up sludge from the deep end, (silver maple leaves and algae) could this be the problem? Should I scoop every single thing out before adding more chemicals? What should my filter be set to during this process?. I love having a pool but the daily trips to Leslie's are killing me. Anyone have any suggestions? I'm all ears!
    Thanks in advance,
    OP
    15k gallon
    IG Gunnite
    Hayward DE 4820 filter
    Pentair Superflo HP pump 1.25 HP
    30,419
    Re: Still green after shock, floc, and pool first-aid?
    Welcome to the forum.
    1. Start in Pool School. read "The ABC's of Pool Water Chemistry" and "How to Shock Your Pool".
    2. Yes, you need to scoop out as much solid debris as you can....not absolutely perfect, but get out as much as you can.
    3. Get your own good test kit. YOur trips to Leslies are expensive, time consuming, and laden with bad advice.
    YOu cannot clear your pool overnight but if you follow the procedures we suggest, we can help you get your pool absolutely crystal clear.
    22,549
    Just echoing what Dave is saying. Do lots of reading in Pool School and order a good test kit and keep scooping while you're waiting on it to arrive.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Welcome
    You've already received good advice, so I'll save myself a lot of typing repeating it all. That being said, if you really want to get in good here, post pictures! We love the green-to-clean stories.
    Incidentally, you have been Pool-stored.
    You're also proof of the simple idea that many people here lose sight of: perfect numbers don't impress very many people; clear, sparkly water does.
    I eagerly await the news that you've purchased a proper test kit and I look forward to seeing pictures.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    There is a part of Pool School that many people do not find and there is a lot of informative reading in it
    pool-school/further_reading
    Since you are fairly new to your pool i would read this regarding your filter
    use-and-care-for-de-filters-t4086.html
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Thanks for y'all's collective help! Test kit is being shipped and should arrive Saturday!
    15k gallon
    IG Gunnite
    I've got the filter taken apart to clean while waiting on test kit today, how do I disassemble the grids on my filter? I'm trying to pull it out, but it looks like the PVC pipes are holding it down. Suggestions?
    15k gallon
    IG Gunnite
    Richard320's Avatar
    Jan 2010
    19,000
    Quote Originally Posted by orangepower
    Here's the manual, with an exploded view. http://www.hayward-pool.com/pdf/manu...rid-DExx20.pdf
    Once the top is off, you undo the center bolt and jiggle and pull until the top piece lifts off. Then you gently jiggle and lift on each grid until they lift out. That's it. There's a few pictures here http://www.troublefreepool.com/post230934.html and some tips other people gave me my first time.
    If you open the backwash valve underneath, you can just wash all the sludge out of the botton down the drain. Don't use too much water pressure or it will splatter and send some of that stuff down into the grid inlet.
    Be careful to put that bleeder hose back in position when you reassemble.
    Thanks for your help! Mrs. OP and I finished putting the filter back in/on just before the storm came through OKC. Already backwashed again this morning. Lots of green. I'm guessing this is good because its not in the pool anymore. Still reading the test kit info, plan on getting some numbers today so I can figure out my next step.
    15k gallon
    IG Gunnite
    30,419
    backwashing green is good but not nearly as good as backwashing brown. Get your chlorine in there and turn that living, green algae to brown.
    Thanks Dave. I love the smell of chlorine in the morning...smells like...victory.
    15k gallon
    IG Gunnite
    3 lb bags of 70% chlorine added, scrubbed the pool with the brush, and back washed...a lot. Psi in the filter is down to 10psi which is good. But I've still got a lot of green. I've calculated the pool size in gallons to 16k-18k gallons and I've added nearly double the amount of chlorine for that amount. All my numbers from my new, handy dandy test kit are primo. But there still isn't a large reaction like I had last year when I did this. Do I continue to just run the filter and backwash every 2 hours until its clean? Or just go for about 15 bags of chlorine and nuke the Christ out of it?
    Thanks everyone
    OP
    15k gallon
    IG Gunnite
    Jun 2012
    Howell, NJ
    977
    70% chlorine, I believe that is Cal-Hypo? What is your CH number? Either way, sounds like you need to re-read the article on shocking your pool, which is linked in my signature.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    I've read the "how to shock" article again for the 50th time and here's my question: what's the difference between shocking to increase to shock level to a certain amount, and just adding 15 bags of 70% chlorine to nuke the **** out of the pool? I mean, seriously. What difference can it possibly make?
    15k gallon
    IG Gunnite
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    A) you are in control of the process, using the knowledge achieved through proper testing to achieve the desired outcome
    B) Our method will save you money in the long run
    C) Just adding 15 bags of ??? is reckless and could possible damage a pool and/or equipment
    There are thousands of threads on this forum that PROVE our methods work. The choice is yours, it is your pool.
    I'm not trying to offend anyone. I'm just asking because that method is out there. I've owned a pool now for 7 months and I'm 26; so I'm just trying to get my bearings.
    On steps three and four after measuring FC levels, it doesn't really address the type of chlorine used to increase Chlorine level. Anyone have a specific bran they prefer?
    OP
    15k gallon
    IG Gunnite
    Richard320's Avatar
    Jan 2010
    19,000
    OP
    Whatever is cheapest!
    Sometimes it works out that Chlorox 8.25% is the best price from a warehouse store. Sometimes 10% from Lowes. Maybe even 12.5% from a pool store. Don't waste money on anything that won't tell you the concentration right on the bottle, and don't buy anything with scents.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Okay so it's past Saturday, did you get your test kit? Post up your results! How is your water looking?
    18'x43' Sport Pool
    I will get numbers up ASAP. As you all have seen on the news, OK got slammed last night so our Internet has been shotty. PH is fantastic, still filtering and back washing lots of green. But I can see the bottom of the pool and where the algae has settled. Tried to vacuum but we had problems with sucking air instead of water. I'm certainly not trying to burn my new pump out! Probably going to make another supply run this week for more chlorine and recheck numbers. Also, when I figure out how to post pics, I will get them up!
    Thanks again everyone,
    OP
    15k gallon
    IG Gunnite
  20. Back To Top    #20
    Here are my numbers as of this morning.
    CYA-50
    FC-.4ppm
    CC-1.0ppm
    pH-7.4
    Seems I don't have much shock in the pool. Filter is running and it seems like I'm back washing everyday and the pool is still green tinted and algae floating around. What do I need to do next?
    15k gallon
    IG Gunnite
