Thread: Polaris Cleaner Hose Wall Fitting
    This past weekend I removed my cleaner from the pool for the first time. I diconnected it from the quick disconnect wall fitting similar to what is shown here http://www.swimnsaveusa.com/13046D29.ht ... 7AodzA8ALg.
    I can not for the life of me get it to connect back on. I can feel it fall into the slots but then when I turn it all the way it doesnt fully lock in?
    Anything i'm missing?
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Polaris Cleaner Hose Wall Fitting
    Assuming no material was chipped off of either the wall fitting or the hose connector, you can try applying a little bit of pool & spa lubricant (same thing used to lube o-rings on the pump cover) to the hose connector.
    Great idea i'll try that today
    Mr. Blue's Avatar
    May 2013
    Spring, TX (Houston)
    95
    Also, make sure the booster pump/pool pump is off. When I first got mine, I had the booster pump on and was fighting it to get the hose connected. I could get it in the wall fitting fine, but had trouble getting the quick connect to lock.
    23K Gallon Freeform Tile Inground
    Hayward Super II 1.5 HP -- Pentair FNSP48 DE Filter @ 120 GPM
    Polaris 3900 Sport (with Booster Pump)
    Pool School Attendee -- The TF-100 Test Kit and the Pool Calculator keep my pool Trouble Free -- BBB Supporter
    Mr. Blue, thats exactly what's happening cant get it to lock. The pool pump was on when I was trying yesterday
    Mr. Blue's Avatar
    May 2013
    95
    Turn it off. I was able to easily lock it once I had the pump off.
