Thread: How long do test chemicals last?
    Jan 2011
    Northern Illinois
    116
    I ordered a TF-100 test kit two years ago and have had great luck with it. However, I was wondering how long the various chemicals in it last? Do certain chemicals in it expire and need to be reordered? Thanks in advance!
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    30,431
    Re: How long do test chemicals last?
    While there is no expiration date, I would say that two years is pushing the envelope a bit.
    Jan 2011
    Northern Illinois
    116
    Thanks. I will place an order tonight.
    May 2013
    North East Ohio
    959
    As a follow up to this, if I just bought a new kit today, and I have chemicals left in the fall. Assume I store them properly, do I really need to replace next May or will they last through the 2014 season and I replace AFTER 2 years.
    Is there a way to tell if bad or not ?
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Mar 2007
    San Rafael, CA USA
    12,082
