Thread: pool salt levels compared to ocean....
    Apr 2013
    NW Ohio
    83
    Ok, so I am a reef keeper and a pool owner....
    Just thinking here....
    My reef aquarium salt level is 1.026 density which is the same as 35ppt.....Typical avg ocean reef environment..
    35ppt is the same as 35,000ppm....
    In a salt pool the aim is about 3500ppm.....So the concentration is 1/10 that of the ocean?
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    22,549
    Re: pool salt levels compared to ocean....
    That is correct!
    Apr 2013
    NW Ohio
    83
    thanks for the confirmation! Maybe I should use my aquarium salt to add to the pool! and go broke
    Or make the pool my 24k gal reef!
    Hahaha...not!!
    Apr 2013
    NW Ohio
    83
    Also is there a way to make a small test sample to see how the salt tastes?
    at say 2000pppm? Like so many tablespoons salt per gallon of water? etc...???
    22,549
    You need 6 grams of salt to raise the ppm salt by 2000 (1995 actually) in a gallon of water. 1 teaspoon is roughly (very roughly) 6 grams.
    Keep in mind that very rarely does water start off with zero ppm salt.
    Apr 2013
    NW Ohio
    83
    Thanks, but gives me a starting point!
