Results 1 to 8 of 8
Thread: Where to to Start
    Where to to Start
    I have been reading postings for the last week and trying to get familiar with all the aspects of owning a pool. I had to drain my pool half way since the CYA level was above 100. I should have my pool filled today. Whats the first steps in getting my pool corrected. It is a 17200 gal pool and has SWG which recommends 4000 salt level Jandy 35 EI. I'm going to add the salt first then what are the next step? Any help would be great.. I have my own test kit TF100.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Where to to Start
    Welcome to TFP!
    The first step is obviously going to be to test your new water. After that, add chlorine, to prevent algae, then start adjusting for the levels as described in Recommended Levels
    Post your test results and information about your pool surface and we'll try to point you in the right direction.
    30,414
    Once your pool is filled and is circulating for perhaps an hour, do a complete set of tests, post them on this thread, and we'll go from there.
    pH will likely be first but it may or may not need adjusting.
    Get a lot of bleach, it won't go bad and you will either need it to shock or to bring your pool up to normal levels.
    OK The water truck came today and filled half my pool. Here are the readings i took.( Added salt already will check tomorrow.)
    FC= .5
    TC= 1.0
    PH= 7.8
    TA= 90
    CH= 160
    CYA= 70
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by jtk11121
    FC= .5
    TC= 1.0
    PH= 7.8
    TA= 90
    CH= 160
    CYA= 70
    WOW, that CYA is after replacing half?
    I would say the next step is lower pH because it will climb out of the comfort zone in a hurry and then add some chlorine - no dichlor shock and no trichlor pucks! - to get that FC up between 5 and 10. You can add one and then add the second after half an hour if the pump has been running.
    I will bring down my ph to 7.2 and add regular bleach. Do i use the pool calc for this?
    38,271
    poolcalculator.com ... yes.
    Thanks everyone for your help One more ? Where would be a good start for my apure35 SWG settings and when should i check my fc in the morning and night?
