Results 1 to 9 of 9
Thread: In-ground Pool Renovation - IL
    Hi all,
    I am new to the forum and hope that with the wealth of knowledge here, I can find some sound guidance.
    We currently live in a home which has a 21' x 28' in-ground, indoor pool. The enclosure and pool were added as an addition to the original house in 1986. We purchased the home in 1998 and enjoyed the pool for several years before equipment issues and financial difficulties forced us to close it down in 2002.
    Things have turned around now and in 2010 we began the renovation process - beginning with the structure itself. There was water damage that needed to be repaired due to failure of the dehumidification system (which was never really installed correctly). We have installed new windows and doors, a correctly sized furnace, 2 new industrial dehumidification units, a proper air exchange system, and new filter and pool heater.
    The structure is good to go, now we need to start work on the pool and pool deck. The pool has a 3 1/2' fiberglass wall with a rubber coping around the top edge which extends down to a concrete ledge. The concrete then slopes down to a depth of about 4' at the shallow end, and 9' at the deep end. There are floor drains in the deck and around the perimeter of the room. All plumbing is in working order. Pool has the skimmer (skimmer door is missing though) and 1 floor drain feeding the filter, and 3 returns. Pump and filter are in working order
    Our challenges that need to be overcome are determining the best option for resurfacing the concrete inside the pool, which is currently painted but flaking badly; and preparing the surrounding deck and possibly a replacement coping. There are areas around the pool edges where the deck concrete has cracked (possibly due to a partial "pop" before we purchased the home), been patched, and is cracking again.
    Do we re-paint, fiberglass, possibly install a vinyl liner? Is there an effective way to repair the deck, replace coping? Is it possible to install some type of thin pavers with a bullnose remodel coping to hide the original coping and cover the concrete.
    I know these are a lot of questions with no visual reference, I will try to upload some pics tomorrow. Any input the great minds here can contribute would be greatly treasured.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: In-ground Pool Renovation - IL
    Welcome to tfp, lunarlandr
    Post your pics and hopefully some of the experts on tfp can chime in with some advice.
    Here are some pics of the project as it stands.
    Thoughts from the talent pool (or would that be pool talent)?
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    You have a very interesting setup there. I'm interested in seeing what things look like when finished.
    Here is a pic of the type of deck treatment we hope to achieve.
    [attachment=0:35upfkq5]uploadfromtaptalk1368730511239.jpg[/attachment:35upfkq5]
    Nov 2011
    Moberly,MO
    1,010
    Look for a company called Thindex. That might be the product name, they make a 1 1/8" paver to cover existing decks. Tnemec makes a good epoxy paint to paint concrete. You may have to sandblast concrete to paint if you are not sure of the existing type of paint. Also there is www.ecosmartepoxysystems.com that could refinish the existing into a complete fiberglass shell.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Cool pool! Where Are you located? Do you have a budget in mind for the remaining repairs?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Quote Originally Posted by harleysilo
    I am in the Northwest suburbs of Chicago, about 55 miles from downtown. I am hoping to be able to finish things up for about $7500.00 or so.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Glad your project is getting there, I have been working on an indoor pool renovation project the last couple of years myself, new wood exterior siding along about 100 feet of perimeter in 2011, and new shingle roof on part and new metal roof on the rest in 2012 and all new water tight light fixtures, then so far this year new repainting the interior walls, new solar heater, new pool pump and perhaps a few smaller things, next will likely be new finish on the concrete floor.
