Thread: New "Green" Muriatic Acid ??
    May 2012
    North of Charlotte, NC
    312
    Was looking for my normal 20 Baum 31.45% at Lowes today (also checked Wally Word) both in the paint section as usual and both places stopped carrying them and now sell this "safer or green" type and it doesn't list the actual % on it Anyone have any idea if its even close to the 20 Baum? And iff not how much of this do I need to use? Still going to look around a bit more but thought I would ask ahead of time in case I have no luck....
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: New "Green" Muriatic Acid ??
    Quote Originally Posted by roadking00
    If it is not listed on the label, I would keep looking.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    May 2012
    312
    Ahh, thanks guys, guess I'll look around a bit more....
