Thread: Template Filter for DE Filter
    Dec 2012
    Manassas Park, VA
    207
    Does anyone know the importance of a Template Filter for a DE filter? Any issues if it is not used?
    http://www.poolpartsonline.com/popup...26size%3dlarge
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    38,303
    Re: Template Filter for DE Filter
    Never heard of it. Guessing that maybe it is used to hold the tops of the grids in place to make it easier to put the manifold back on after you have taken it apart for cleanings.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    It appears it is just to align the grids and hold them in position before you stick the top manifold on. I can see where it would make t easier to do. I don't think it's mandatory.
    c. After all elements have been positioned on the bottom spreader, place the plastic template over the element spouts. This will keep the elements positioned correctly.
    http://www.poolcenter.com/pentair-fns-de-filter-OM.pdf paragraph II.H.4.c.
