Thread: Hayward Heater Part rcvd is different - Replacement Part???
    SFowler252's Avatar
    Jun 2012
    Elgin, Illinois
    5
    Hello! Looking for Hayward Heater help.
    Pool ownership is great since switching to BBB. Thanks to this forum and everyone here. Opened it on a Sunday was looking great and passing all its tests 2 days later. Yeah!
    Can't swim though the water is only 66. Ugh! Grandkids want to swim. Started up the heater and nothing...called the repair man. It's a Hayward H100ID1. He said we needed new Hi-Low pressure switches and water pressure switch but that he couldn't get back to install them for 10 days. We decided to order and install them ourselves. How hard could it be. Ordered them online according to their diagram of the heater. Well they sent a different water pressure switch than what is in it. Found the book and it should have been part # IDXWPS1930 but they sent a CZXPRS1105. Does anyone know if this a replacement part? Will it work or do I need to send it back?
    It's hot outside and the solar blanket is not warming it up very fast.
    Any help would be appreciated.
    Shelly
    Shelly
    7,400 Gallon 18' Round Vinyl Above Ground Pool installed in 2006
    Hayward Pro S180T Sand Filter/Power Flow Matrix 1 hp Pump, DE added, Daily runtime 6 hours
    Hayard Gas Heater HD100ID, Solar Cover, "Willy" the Aquabug & TF100 Test Kit with Speed Stir
    Maintaining BBB Method: 6 FC using 15% Bleach, 50 CYA, 50 ppm Borates & 2430 ppm Salt for Feel
    22,550
    Re: Hayward Heater Part rcvd is different - Replacement Part
    Is there any set point range on the two switches?
    It looks like an interchangable part but I can't find the setpoint anywhere.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You have the correct pressure switch. The part number you have was probably changed at some point and this is the new part number.
    You can see on this web site that they list that part number they sent you.
    http://www.parts4heating.com/Pool-Heate ... -s/973.htm
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
