Thread: stenner pump port size?
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Plumbers are here, what size fitting do I need for the stenner pump? 1/2"?
    Thanks!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Re: stenner pump port size?
    For the injection nossle.
    May 2011
    Long Grove, IL
    117
    Quote Originally Posted by NoFear95
    Yes, the injector nozzle will fit into a 1/2" FPT fitting.
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Thank-you! I had the plumber put 2x in-line. One for chlorine and another for acid if I so desire later on lol.
