Thread: Safe to swim with FC 6?
    Apr 2013
    Dominican Republic (Caribbean)
    6
    Hello my pool got an algae attack and I shocked the pool 2 times, the water is blue and a little bit cloudy.
    I shocked those 2 times aboyt 6 days ago.
    I want to swim todat but im a little bit sacred, I tested the qater with taylor test and it guves me these results
    FC 6
    CC 0.4
    pH 7.4
    CYA 80
    It's a SWG pool
    Is it safe to swim?
    3K gal, AG vinyl,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Safe to swim with FC 6?
    Welcome!
    pool-school/chlorine_cya_chart_shock shows that 6 is the minimum you need to maintain for your CYA level.
    The chlorine is no cause for concern, the cloudiness is. You're not done with the shock process.
    Looks like it's time to enroll in Pool School.
    Apr 2013
    6
    Hello, what can I do to put oyt the cloudiness? Shock again?
    Is it aafe to swim with the cloudiness? Is not a big cloudiness you can see the bottom,
    3K gal, AG vinyl,
    30,419
    Yes, it's fine to swim.
    Getting rid of the cloudiness requires you to learn how to shock the pool correctly so the cloudiness will clear. read "How to Shock Your Pool" up in Pool School.
