Thread: Bubbles/Soapy/Suds floating on top of water
    Mar 2012
    Yukon, OK
    19
    I am just now opening my pool from a dark green swamp by following the directions from this forum. I'm on day 4, pump has been running 24/7 and I've been keeping the pool up to shock level as much as possible. Any clue on where these bubbles are coming from? They do seem to be blowing out the returns...
    Today's test: (I added bleach and muriatic acid after yesterday's test)
    FC 13.5
    CC 1.5
    TC 15
    pH 7.6
    T/A 130
    CH didnt test
    CYA 75
    Yesterday's test:
    FC 6
    CC 1
    TC 7
    pH 8.2
    T/A 130
    CH 70
    CYA 80
    My Pool:
    Starting construction 4/2018:
    32,000 Gallon, IG, Vinyl, 18'x21'x40', Pentair VS Pump, Pentair Sand Filter
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Bubbles/Soapy/Suds floating on top of water
    Welcome to TFP!
    Did you use any algaecide? That can cause foaming...but even if you didn't, a swamp cleanup often does funny things all by itself. Keep at it!
    Mar 2012
    Yukon, OK
    19
    Ok, I did not use algaecide...only liquid unscented bleach. Thanks, I'll keep at it! So I should bring it up to shock level again right now, correct?
    My Pool:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by dkellerd
    Yes. The more diligent you are about maintaining FC, the faster it clears.
    I've seen pictures with foam here before, not a cause to worry.
    38,237
    Welcome to TFP!!!
    Looks like you are making pretty good progress. Your FC looks a little low for the shock process ... if you CYA is up near 80ppm (which could warrant replacing 1/3 of the water in itself) then the shock FC level you should be maintaining is 30 ppm:
    pool-school/chlorine_cya_chart_shock
    Yes, keep raising it up to shock level every hour if you can.
    Mar 2012
    Yukon, OK
    19
    Great news! Thanks alot! I've spent alot of time reading this forum over the past year...really appreciate the help!
    Heading out to go dump some more bleach now...cheers!
    And my CYA was over 110 end of last year...I'm just happy to see it's at 75 now. I figure I'll do the initial vacuuming to waste, then refilling the pool may bring the CYA down into proper levels...
    My Pool:
