Pentair Superflo Motor Replacement
[email protected]
0
2
Indianapolis, IN
Hayward Aqua Rite (T-15)
Good afternoon. I had to replace the motor on my 1.5 HP Pentair Superflo Pump last summer. I replaced it with a AO Smith Centurian B2854. At that time, I replaced the pump seal and all of the o-rings and seals. It had a small leak all summer and I took it apart and reinstalled it at least 3 times. I am doing it again. I have bought a new set of pumps seals, US SEAL PS-200. I believe it leaks around the shaft seal not the pump casing. Any hints or suggestions would be greatly appreciated.
Continuous failure of seals is either an installation problem (wrong direction) or the motor shaft is bent. Try running the motor while the wet end is removed and watch the impeller for any wobble.
