Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Fixing last years mistake!
    May 2009
    NC
    95
    new-liner-install-gone-wrong-vermiculite-bottom-collapsed-t49675.html
    The link above discusses the mistake made last year when I needed a new liner. My local pool store failed to show up several times to provide an estimate for a liner replacement last year, so I went shopping on the internet for a company. After talking to several companies last year, we (my wife and I) ended up hiring Cascade pools in Chesapeake VA to do the liner replacement. Between the fancy website and the owners claims, It seemed like a professional company. The guy that Cascade pool's contracted to do the liner replacement, made mistakes, and he was rude. I found out that Cascade Pools simply contracts others to do various jobs. It is my understanding he is a one man show, it's not like he has crews or employees.
    That's the past, and now I have some progress to report concerning the repairs my pool has received in the last couple weeks. After locating someone with decades of pool experience, we started by connecting a pump to the old well points. First we connected to the one Gus used last year, and it pumped water and a pile of sand nearly immediately, then we connected to the one on the other side of the deep end, and it didn't move any water. There is a third well point adjacent to the diving board, but due to the distance it runs under the concrete, we elected to not even try it. We washed-in a couple of new well points, one on each side of the deep end, and they moved plenty of water, but no sand. At this point we drained the pool with the understanding that more well points might be required, but we would not know until the pool was drained. Once the pool was drained and the liner rolled back into the shallow end, we could see the collapsed vermiculite surface, from last year. Oh, I almost forgot, I found Gus's screwdriver, the one he left under my new liner, in the deep end.
    18x36, IG, Vinyl, 25,000 gal, S-200, 3/4 Super Pump, BBB or bust!
    I have a new bottom, new plumbing, and everything is working good!
    May 2009
    NC
    95
    Re: Fixing last years mistake!
    From last year before the new liner was installed
    May 2009
    NC
    95
    Another picture from last year
    May 2009
    NC
    95
    Another picture of the new liner from last may, and this was the last time I ever saw Gus, because he never returned to my house as far as I know. He left his tools and mess all over my yard, and I had to clean it up. Several days later one of his crew came by to pickup the tools.
    May 2009
    NC
    95
    This picture is about one week old, showing the damage to the bottom. There are two well points connected and pumping about a half basket, and water is still leaching over the slab
    May 2009
    NC
    95
    Another recent picture
    May 2009
    NC
    95
    The screwdriver that spent the winter under my pool liner
    May 2009
    NC
    95
    Because this screwdriver was left under my liner, Jim Refunded my money. Had it not been there, I'm sure He would have not done so.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    So could you like see the outline of the screwdriver, or was it embedded into the creete?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Casey's Avatar
    SW PA
    10,461
    OMG!!!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Wow, so if someone named Gus shows up to fix your pool - run for the hills.
    Hope everything works out.
    May 2009
    NC
    95
    Quote Originally Posted by harleysilo
    The screwdriver outline could be seen, protruding above the bottom, it actually caused a small hole where it was stretched around the handle. We would have rehung the liner today, but the pool guy forgot his glue, actually he drove his wife's car instead of his truck. We needed the glue to install a patch on the underside of the liner where the screwdriver was. The plan is to hang the liner tomorrow.
    May 2009
    NC
    95
    Damaged area removed
    Apr 2012
    South Dakota
    87
    Is that company paying to fix your pool?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    May 2009
    NC
    95
    I put half down for the liner job, and then after I found the bottom collapsed I asked what he was going to do about it, at that point he refused to take any ownership for that damage. He blamed it on ground water. It wasn't until I found the screwdriver until he showed any concern. I asked for my money back, or otherwise we could go to court and let a judge make the decision. He brought my check over the next day.
    Here I am a year letter, with a do-over. This time I have someone who knows how to work on a pool. But I am paying for it.
    May 2009
    NC
    95
    The two major areas of collapse after repairs
    May 2009
    NC
    95
    Four well points and 20 bags of vermiculite later, the walls in my pool are nearly finished
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Looks good.
    How much does something like that cost?
    May 2009
    NC
    95
    Bottom repairs complete
  20. Back To Top    #20
    May 2009
    NC
    95
    Screwdriver rust on the underside of the liner, and a hole to the left of the rust
