Results 1 to 8 of 8
Thread: Plumbing for Deck Jets
    Feb 2012
    Maryland
    400
    Im going to have 4 deck jets, 2 on each long side of the pool.
    The install instructions say to "create an equal pressure loop". Im not quite sure what that is.
    Would it work if I ran from the pad a 2" pipe down one side, a T dropping it down to 3/4" and up to deck level, continue on around the entire pool perimeter doing this and at the last jet run it past the T for about a foot and cap it.
    Would it be better to have 2 2" feeders coming from the pad, one down each side?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Plumbing for Deck Jets
    An equal pressure loop means that you completely loop the pipe back around and connect it back where it started. If you don't do that, your jets won't all have the same pressure. 1 2" feeder will be plenty.
    Feb 2012
    Maryland
    400
    Just to make sure im clear.
    Basic drawing. From the left coming out of a valve, hit a T and take pipes in both directions, stubbing up jets and looping all the way around.
    Im just trying to think this through, but wouldnt this be trying to force water BACK into the output side?
    Oct 2009
    3,899
    That's the right idea. What it does is equalize the pressure at the four jets. If you run them all in a line, the first jet will shoot much further than the last.
    Apr 2012
    Mason, Ohio
    119
    I have four deck jets - each is plumbed separately to the pad. It's nice to be able to control them individually.
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    Feb 2012
    Maryland
    400
    Quote Originally Posted by Mike_k
    So you have a ball valve on each line then? I kind of like that idea.
    When I did our pool plumbing last year we used 4 deck jets in a loop like described. I just use the jandy valves to control them. To me either you want them on or not but I could see if everyone was in the shallows but you still wanted the deep end ones on where it would be helpful. We love ours. It makes such a relaxing sound. I used 2" pipe and Rees it off with 3/4 just because I ran 2" everywhere else and what I had. With 4 you could go with 1" I believe if I remember the instructions that came with it correctly.
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Apr 2012
    Mason, Ohio
    119
    Quote Originally Posted by ssgumby
    Yeah - here's what it looks like at the pad:
