Thread: staining of new plaster
    Apr 2013
    Las Vegas, nv
    11
    I need some advise. My plaster is a week and half old, water is crystal clear, and is well balanced(ph keeps rising, but that's typical with new plaster, right?)
    My problem is I keep getting stains from organics falling into pool (leaves, bird droppings). Is this normal?
    Damon
    New owner, first pool,30+ yr old plaster/gunite,15k gal. White quartz plaster (NEW 5/5/13!)Hayward tristar variable pump Hayward pro grid D.E. Hayward h heater LED color lights.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: staining of new plaster
    redneck5185:
    Welcome to TFP
    I get occasional stains in my pool from some sort of plant/pollen. The stain always goes away within 24 hours or less due to the normal maintenance chlorine level. No brushing required.
    And, yes, it is normal for pH to drift up on new plaster.
    Apr 2013
    Las Vegas, nv
    11
    Thanks!!
    Damon
