Thread: In Line Chorlinator - For Bleach
    Mar 2013
    CT
    349
    I see the in line chorinators/feeders for the tabs are about $100 or so.
    Are there in-line chorinators that are used with bleach? If so, how do they compare in price?
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    22,544
    Re: In Line Chorlinator - For Bleach
    The closest thing to a auto feeder for bleach is either the Liquidator (LQ) or a drum and injection pump. The LQ is a little more than a tablet feeder and the injection pump/drum is about $300.00 or so. Either way is definitely worth it.
    Mar 2013
    CT
    349
    Thanks!!!
    I found the HASA Liquidator via Google for $165. Not a bad price. Is 8 gallon the standard size?? That's the one I came up with.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    dschribs:
    You can read more about the Liquidator & Chemical Automation here: http://www.troublefreepool.com/chemi...dator-f81.html
