Results 1 to 9 of 9
Thread: new BBB'r.... New TF-100 test and results:
    Apr 2013
    NW Ohio
    83
    Pool opened about 3 weeks ago. Just 12.5% and muratic acid thus far:
    FC: 1.5
    CC: 0
    TC: 1.5
    pH: 7.5
    also got 1 on the taylor OTO in kit
    TA: 80
    CYA: ~10 as i pretty much was full tube
    CH: 260...at 250 was more purple and 260 turned faint blue
    last yrs 5 way test strips show I should be testing somewhat correct:
    pH ~ 7.2,
    FC ~ .5-1
    TA ~ 40
    CYA ~20
    18x37 Vinyl Grecian (24k gals) 8' Inter fab(la mesa) Diving board w/ waterfall & Led, Pentair Laminars & Intellibrite 5g
    Star Rite System 3 Cartridge Filter, IntelliPro 3HP Variable Spd Pump, Max E Therm 400k BTU,
    Pentair Easy Touch 8 & actuators,...Now looking to BBB
    Apr 2013
    NW Ohio
    83
    Re: new BBB'r.... New TF-100 test and results:
    Also I plan to test borates & salt and add both as discussed in another thread of mine for the silky feel of water.
    Am I safe to do the additions this weekend?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    How does your water look? If its clear, your FC is holding overnight and you are in to maintenance phase.... if you plan to use bleach for chlorination, raise the CYA to 50 and bump your FC up to 6 and keep it above the new minimum of 4 at all times. Than go ahead and do your salt/borate plans.
    Any other questions as you have been absorbing the info here at TFP?
    Apr 2013
    NW Ohio
    83
    Pool is sparkling clear. So i'd say i am in maintenence phase.
    Haven't done the overnight test. Will do tonight. I plan to bump the FC & CYA for sure.
    Apr 2013
    NW Ohio
    83
    pH will if anything rise from the waterfall & laminars? I only run them for like 2 hrs at night right now so probably not much?
    11,969
    Eh, shudn't be bad with a TA of 80 and once the borates are in that should minimize it even more. I wouldn't worry about it.
    Apr 2013
    NW Ohio
    83
    Also since I have a liner pool is there a chlorine level that starts to get harsh to it? fade it etc...
    Is it the FC or CC that is what fades & deteriorates over time?
    30,432
    If you stay within the guidelines we suggest, the chlorine will not harm you liner.
    If you go w-a-a-ay outside the guidelines, all bets are off.
    Apr 2013
    NW Ohio
    83
    simple enuf!
