Results 1 to 16 of 16
Thread: New Pool Owner, old pool, draining (stain pics added)
    May 2013
    Edmond, OK
    10
    Hello and thanks in advance for your help. We purchased a home with a neglected pool and am opening it for the first time. All equipment works but the pool needs some TLC.
    I have already made my fair share of purchases at the pool store and am ready to do this on my own with the help from this website. I'm draining the pool for several reasons. 1) CYA levels of 120+++ and CH is 500. 2) main drain covers need to be replaced for safety I'm told. 3) Some staining that hopefully I can scrub off.
    I am very interested in BBB and am willing to put in the work to learn it.
    Here are my questions.
    1) what do you recommend to take off calcium deposits from tile?
    2) chewable vitamin c did help remove some staining as did the shock process. Pool looks much better but not perfect.
    3) I have the pool calculator app and will refer to that for amount or product to use. Is there a certain order to do it in?
    4) Do I just start dumping in product as I fill the pool? Also I assume I don't add the salt until I shock and get CH levels up?
    Here are the test results for my tap water. (Tested with local YMCA Test kit for their pools)
    PH 8++
    Chlorine: 0
    TA 230
    CH 30
    TDS 650
    CYA 0
    Additional Notes:
    I have cleaned the filters and acid washed them. I hope to make it through this season before purchasing new. I ran a metal cleaner through the pool as well. I will be ordering a test kit tonight so I can do my own testing.
    Hopefully I have provided enough information. I look forward to your responses.
    Thanks!
    Jay
    _________________
    19.5K gal, plaster, 1.65HP AO Smith USQ1152 pump, IntelliChlor IC40 SWG, Pentair CCP 420 Cartridges, POLARIS 280 Cleaner. Kidney shaped pool with 6' spa that spills into deep end.
    First time pool owner as of 1/2013. Pool constructed in 1997.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Pool Owner, old pool, draining and starting over.
    Welcome to tfp, Ttime
    Quote Originally Posted by Ttime
    http://www.troublefreepool.com/pool-...alcium_scaling Post a picture.
    Stains removable with a vitamin C tablet are metals, for that and if it is widespread, an ascorbic acid treatment will help. See: http://www.troublefreepool.com/pool-...metal%20stains
    The stains removed by the shocking process are organic. Did you do a complete shocking process and pass all three criteria simultaneously? See: http://www.troublefreepool.com/pool-...king_your_pool
    Generally do it in the order that the calculator shows.
    Are you doing a full drain and refill? If yes, do you have a high ground water table level? If you do, this can pop your pool out of the ground... not good.
    May 2013
    Edmond, OK
    10
    Thanks for the quick response.
    Are you doing a full drain and refill? If yes, do you have a high ground water table level? If you do, this can pop your pool out of the ground... not good.[/quote]
    No I don't have at high ground water table. After reading a few posts on here I did some checking and am in the clear. Also my neighbor behind me did a full drain and refill last year with no issues.
    Thanks!
    Jay
    _________________
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What brand/model test are you using? I would redo the cya test by mixing half pool water and half cya free water (tap water is fine for this dilution) and repeat the test. Take that result and multiply it by 2 to get your pools cya level. Then we will know how much you have to drain/refill...there is probably no need to do a full drain and refill unless you are going to do an acid wash to remove some scale.
    May 2013
    Edmond, OK
    10
    No, I didn't. The pool store said to sprinkle 2 packets of "shock" around the edge of the pool and water would clear up. Then bring in another sample to test. That's when I discovered the extremely high CYA, etc.
    That was enough of the pool store for me.
    I now know that there is a full process to follow. I'll read the instructions for shocking here and do what is suggested with the 3 criteria.
    Thanks!
    Jay
    _________________
    May 2013
    Edmond, OK
    10
    Quote Originally Posted by linen
    I think I will go ahead and do an acid wash. Are there acid wash instructions you can refer me to?
    Plus i'll probably go ahead and replace the main drains per code from our home inspection. I think they are called anti entrapment covers. Does anyone ave any suggestions on which of those are recommended. I have 8" drains.
    Thanks!
    Jay
    _________________
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    We do not have an official set of instructions on tfp for acid washing. Some on here do not consider it a diy job. There is some info in this post: http://www.troublefreepool.com/acid-...5.html#p321613
    Before doing that I would post some pics and let some of the calcium scaling experts on here comment.
    May 2013
    Edmond, OK
    10
    Ok, I'll snap some pics tomorrow and post them. I don't really want to acid wash, but since I am draining anyway I thought I might try to figure it out.
    These forums have been extremely helpful!
    Thanks!
    Jay
    _________________
    May 2013
    Edmond, OK
    10
    OK, here are some pictures. It's cloudy this morning so I hope it is bright enough to tell. What do you think?
    Thanks!
    Jay
    _________________
    May 2013
    Edmond, OK
    10
    Re: New Pool Owner, old pool, draining (stain pics added)
    Ok, the drain is complete and I acid washed the pool and replaced the drain covers. The plaster looks great and almost all stains are gone. I also powerwashed the tile which removed most of the calcium deposits.
    I'm refilling now. Looking forward to beginning BBB. I guess I'll use the pool calc to start balancing things out. Then do the shock process recommended above.
    Am I on the right track?
    Thanks!
    Jay
    _________________
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    The shock process is probably not needed with a fresh fill. Maybe go a little higher on FC initially, since the CYA won't dissolve instantly and there may be some nasties inside the plumbing or filter.
    May 2013
    Edmond, OK
    10
    Thanks Richard. Good news on not having to shock.
    Time to go to the store and stock up on supplies for balancing.
    Does it matter when I add the salt? Do I need to get test values in order first or go ahead and start pouring it in?
    Thanks!
    Jay
    _________________
    Richard320's Avatar
    Jan 2010
    19,034
    Conventional wisdom is to hold off on the salt until the pool is balanced. That's one less variable to mess you up. Give yourself a couple days to get used to things and be sure the pumps and filter are good and the water is sparkling. And let the CYA completely dissolve - a SWG won't be able to keep up with the demand until CYA is dissolved. Then add salt and fire off the SWG. Do you have kids? Scroll down in this thread until you see the highlighting.
    May 2013
    Edmond, OK
    10
    Thanks for your help. Sounds like a fun event!
    Thanks!
    Jay
    _________________
    May 2013
    Edmond, OK
    10
    Ok. First of all I couldn't have done this without this forum. Thanks to everyone.
    My TFT100 test kit arrived today and here are the results.
    FC 3
    PH 7.8
    TA 80
    CH 200
    CYA 50
    It looks to be in pretty good shape and the water is crystal clear.
    I have added bleach, borax, muratic acid, and cya over the last 5 days primarily off of basic test kit results and a trip to the local pool store for TA and CYA.
    Any other suggestions before I add salt? Also, how high do you think my chlorine should be prior to adding salt?
    I did not shock based on Richards recommendations.
    Thanks!
    Jay
    _________________
    38,346
    The minimum FC for that CYA is 4ppm, maintain at least that until the SWG is fired up.
    Also test the salt in the water before you add any as it is not likely 0.
